Tuesday at 09:14 AM2 days On Armbian 26.8.3 (current 6.18.45, extlinux boot), my NVMe (SK hynixBC511) in the M.2 slot disappears after a few seconds to minutes, idleor under load: pcieport 0001:00:00.0: AER: Uncorrectable (Fatal) error message received from 0001:00:00.0 nvme nvme0: controller is down; will reset: CSTS=0xffffffff, PCI_STATUS=0x10 nvme nvme0: Disabling device after reset failure: -19Cause: ASPM L1 on the K1 root port. bananapif3.conf adds pcie_aspm=offto armbianEnv.txt only since the switch to boot.scr (2026-08-30), so26.8.x images booting via extlinux don't have it. Workaround: append pcie_aspm=off to the append line in /boot/extlinux/extlinux.conf(keep the line under 255 characters on this U-Boot). With it: stable(fio verify, burst/idle cycles, soak), Gen2 x2, ~800 MB/s read.A kernel-side fix (as in mainline's pcie-spacemit-k1) is proposed inGitHubSpacemiT K1: PCI: do not advertise ASPM L1 (NVMe drops of...Description With ASPM L1 enabled (default on DT platforms since 6.18), an NVMe in the BPI-F3 M.2 slot drops off the bus at idle or under load: AER: Uncorrectable (Fatal), Surprise Down, then nvme n....
