Hello everyone. I would like to create an update system, which via a link on a web page, will check on an ftp server and if a version is newer, download the img file and install it.
it is the installation part that poses me big problems. to write an img on the sd we  must use the command dd if = ..... of = ......
But since the sd is used it does not work.
I had thought of going through berryboot but a priori it is not functional on the m2. If someone has an idea
thank you :)
