I have Google assistant running on Armbian on an Orange Pi Lite headless system. The sound output is via a USB sound card, as the Orange Pi Lite does not have n audio jack, but the volume is too low, even with volume set to max on alsamixer. I've been trying to figure out how to enable pre-amp, but have been unsuccessful. The current asoundrc is:
pcm.!default {
 type asym
 capture.pcm "mic"
 playback.pcm "speaker"
pcm.mic {
 type plug
 slave {
 pcm "hw:0,0"
 format S16_LE
pcm.speaker {
 type plug
 slave {
 pcm "hw:2,0"
The only options in alsamixer are those pictured below and even with the volume at max, the output is too low. PCM does not appera to make any difference. I know that the USB card and speaker combination are capable of more, so I suspect it to be an ALSA issue. Any ideas on how I can enable pre-amp or otherwise increase the volume?
I've figured it out. It's nothing to do with Alsa, rather Google Assistant has the ability to control volume, i.e. "OK Google, turn it to 10"
