I run ARMBIAN 5.38 stable Debian GNU/Linux 8 (jessie) 4.14.18-sunxi on an Orange Pi Zero.
Cron and its timezone are causing me problems: it's initially one hour out - all root crons run an hour early.
If I run dpkg-reconfigure tzdata and set the correct region/place, cron then runs correctly until the next reboot.
I can see no difference between the localtime and timezone files before and after the reconfigure (strangely, the localtime link is replaced by a file following a reconfigure - this is different from my other Armbian machines).
I can work around the problem as follows: following a start/reboot I then restart the cron service - the cron timing thereafter works correctly.
I guess there may be a issue with the systemd cron.service - perhaps it starts the service too early in sequence?
Any suggestions/explanations gratefully received.
