kelb Posted February 15, 2018 Posted February 15, 2018 Hi All, I have bought an android tv box (H96 MAX) with rk3399 inside. I want to install ubuntu on it and have access to mali gpu as well. Is there a version of ubuntu (with desktop-GUI) stable or unstable that I can use. Thank you in advance.
Slack Posted March 12, 2018 Posted March 12, 2018 Very simple. Take the distro from Opi site, dd it on the SD-card. insert and turn on power. It is running. Later, the kernel changed (recompiled by me) to root@localhost:~# uname -a Linux localhost 4.4.114 #11 SMP Mon Mar 12 08:46:26 UTC 2018 aarch64 aarch64 aarch64 GNU/Linux The problem is with dtb file: partially it works. USB2 is ok, HDMI is ok, Ethernet is ok. But: [ 0.809301] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2 (file dptx.bin present) So, USB3 (and DP) is off (both type-C and normal USB3 blue socket; it works in Android). Also, I cannot check AV output and ALSA shows only SPDIF, that has no controls. I think the only need is any correct dtb file to work with the board.
marcthilbault Posted April 6, 2018 Posted April 6, 2018 Hello, I am also looking to run a linux distro on the same h96 max box with a RK3399 chip. have you had any luck in getting dp or USB 3 working? I should mention that I am a noob to this and would appreciate any step by step tutorials you could link me to to help me through the process. Thanks in advance.
