I download Mozilla IOT, then i send yarn command my orange pi pc2 is frozen... I reboot it, but pipc2 now in cycle reboot.
Console log:
U-Boot 2017.11-armbian (Jan 30 2018 - 17:36:47 +0100) Allwinner Technology
CPU: Allwinner H5 (SUN50I)
Model: OrangePi PC 2
DRAM: 1 GiB
MMC: SUNXI SD/MMC: 0
In: serial
Out: serial
Err: serial
Net: phy interface7
eth0: ethernet@1c30000
starting USB...
USB0: USB EHCI 1.00
USB1: USB OHCI 1.0
scanning bus 0 for devices... 1 USB Device(s) found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3100 bytes read in 216 ms (13.7 KiB/s)
## Executing script at 4fc00000
U-boot loaded from SD
Boot script loaded from mmc
306 bytes read in 176 ms (1000 Bytes/s)
29826 bytes read in 381 ms (76.2 KiB/s)
339 bytes read in 421 ms (0 Bytes/s)
Applying kernel provided DT overlay sun50i-h5-analog-codec.dtbo
374 bytes read in 448 ms (0 Bytes/s)
Applying kernel provided DT overlay sun50i-h5-i2c0.dtbo
374 bytes read in 457 ms (0 Bytes/s)
Applying kernel provided DT overlay sun50i-h5-i2c1.dtbo
1215 bytes read in 507 ms (2 KiB/s)
Applying kernel provided DT overlay sun50i-h5-spi-add-cs1.dtbo
780 bytes read in 526 ms (1000 Bytes/s)
Applying kernel provided DT overlay sun50i-h5-spi-spidev.dtbo
4179 bytes read in 443 ms (8.8 KiB/s)
Applying kernel provided DT fixup script (sun50i-h5-fixup.scr)
## Executing script at 44000000
4916708 bytes read in 538 ms (8.7 MiB/s)
12943368 bytes read in 918 ms (13.4 MiB/s)
## Loading init Ramdisk from Legacy Image at 4fe00000 ...
Image Name: uInitrd
Image Type: AArch64 Linux RAMDisk Image (gzip compressed)
Data Size: 4916644 Bytes = 4.7 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 4fa00000
Booting using the fdt blob at 0x4fa00000
Loading Ramdisk to 49b4f000, end 49fff5a4 ... OK
reserving fdt memory region: addr=4fa00000 size=6d000
Loading Device Tree to 0000000049adf000, end 0000000049b4efff ... OK
Starting kernel ...
Loading, please wait...
starting version 232
done.
Begin: Will now check root file system ... fsck from util-linux 2.29.2
[/sbin/fsck.ext4 (1) -- /dev/mmcblk0p1] fsck.ext4 -a -C0 /dev/mmcblk0p1
/dev/mmcblk0p1: clean, 382485/460672 files, 1618715/1905664 blocks
done.
done.
[ 3.227614] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000004
[ 3.227614]
[ 3.236765] CPU: 2 PID: 1 Comm: init Not tainted 4.14.15-sunxi64 #30
[ 3.243116] Hardware name: Xunlong Orange Pi PC 2 (DT)
[ 3.248253] Call trace:
[ 3.250717] [<ffff0000080884d8>] dump_backtrace+0x0/0x3a8
[ 3.256120] [<ffff000008088894>] show_stack+0x14/0x20
[ 3.261178] [<ffff000008950328>] dump_stack+0x9c/0xbc
[ 3.266232] [<ffff0000080acf54>] panic+0x130/0x28c
[ 3.271027] [<ffff0000080b1148>] complete_and_exit+0x0/0x20
[ 3.276602] [<ffff0000080b11b0>] do_group_exit+0x38/0xa8
[ 3.281918] [<ffff0000080bbdd8>] get_signal+0x128/0x460
[ 3.287145] [<ffff0000080877a0>] do_signal+0x80/0x680
[ 3.292198] [<ffff0000080881b8>] do_notify_resume+0xc0/0xf8
[ 3.297771] Exception stack(0xffff000008033ec0 to 0xffff000008034000)
[ 3.304213] 3ec0: 0000aaaae53a9010 0000ffffae7d07c8 0000000000000000 0000000000000000
[ 3.312043] 3ee0: 0000aaaae53a9240 0000000000000081 0000ffffaea61b51 0000000000000003
[ 3.319872] 3f00: 0000000000000080 0000ffffae8b39f8 0101010101010101 0000000000000018
[ 3.327702] 3f20: 00000000000003f3 0000000000000000 0000000000000000 0000ffffaeab4cc0
[ 3.335532] 3f40: 0000ffffae8b3008 0000ffffae7e43b0 0000000000000a03 0000aaaae53a9010
[ 3.343365] 3f60: 0000aaaae53a9010 0000ffffffae7008 0000ffffffae7010 000000000000000a
[ 3.351198] 3f80: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 3.359030] 3fa0: 0000000000000000 0000ffffffae6ee0 0000ffffae7dd2b8 0000ffffffae6ee0
[ 3.366863] 3fc0: 0000ffffae7de0f4 0000000060000000 ffffffffffffff9c 00000000ffffffff
[ 3.374695] 3fe0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 3.382529] [<ffff000008082ec0>] work_pending+0x8/0x10
[ 3.387670] SMP: stopping secondary CPUs
[ 3.391597] Kernel Offset: disabled
[ 3.395089] CPU features: 0x002004
[ 3.398490] Memory Limit: none
[ 3.401552] Rebooting in 10 seconds..
i try this manual but not success, try other microSD card, not success. With new clear img - boooting is ok... Old flash mount on other Ubuntu, and i see whole content. Neeed help to repair my old flash - many programs & settings on it. Thanx for any help.
