Hello, I have a board similar to the bananapi m3, the main difference is that it has a ram type DDR3 memory instead of a type LPDDR3.
If I compile in the following way:
./compile.sh BOARD = bananapim3
The result is:
HELLO! BOOT0 is starting!
boot0 version: 4.0.0
rtc [1] value = 0x00010000
rtc [2] value = 0x00020000
rtc [3] value = 0x00030000
DRAM DRIVE INFO: V1.0
DRAM Type = 7 (2: DDR2.3: DDR3.6: LPDDR2.7: LPDDR3)
DRAM normal_mode value: 00000001
DRAM CLK = 672 MHZ
PMU: AXP81X
ddr voltage = 1200 mv
using ic A83T
using axp AXP813
DRAM zq value: 00003bfb
initializing SDRAM Fail.
Do I need to change the type of memory in the boot0, can someone help me?
Pd: Sorry for my language.
Best regards
