network config / routing table question
[sorry if this is in the wrong forum category]
I am a new user and have got my OPi zero running up until the console (starting message), via ethernet.
I have used a router with IP 192.168.4.1 as DHCP server, which is not connected to internet. The routing table is accordingly similar to [1]
Wifi is not yet set up. When I want to, it should connect to a different AP/router (say operating as 192.168.1.1 seen over wlan0), and therefore also the routes have to be adjusted.
My question is: can I delete the default route in [1] while still retaining connection to the Pi via Ethernet? (from the PC which is on the 192.168.4.0 net, say 192.168.4.10?)
Asked the other way: what is the minimum line required in the routing table?
In my understanding, the second line in [1] should be enough to hold the connection.
[1]
root@orangepizero:~# route -n
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         192.168.4.1     255.255.255.0   UG    600    0        0 eth0
192.168.4.0     0.0.0.0         255.255.255.0   U     0      0        0 eth0
