DH1TW Posted March 27, 2018 Posted March 27, 2018 Hi, I'm running Armbian 5.38 with kernel 3.4.113-sun8i on an Orange Pi Zero. I'm writing an audio streaming application using the portaudio library for accessing the soundcard. It seems that the OPI Zero samplerate for the built-in microphone is configured at 24kHz instead of 48kHz. $ cat /proc/asound/card0/pcm0c/sub0/hw_params access: MMAP_INTERLEAVED format: S16_LE subformat: STD channels: 1 rate: 24000 (24000/1) period_size: 960 buffer_size: 1920 If I connect an external USB soundcard, I get the expected values: $ cat /proc/asound/card2/pcm0c/sub0/hw_params access: RW_INTERLEAVED format: S16_LE subformat: STD channels: 1 rate: 48000 (48000/1) period_size: 6000 buffer_size: 24000 I think the microphone input of the OPI Zero's builtin audio codec should also be 48kHz, shouldn't it? The way it currently works causes problems with portaudio. Tobias
