I am attempting to build the following:
Full OS image for flashing
Do not change the kernel configuration
nanopineo2
next or dev kernel same error
stretch or xenial same error
[ o.k. ] Downloading sources
[ o.k. ] Checking git sources [ u-boot v2017.11 ]
[ .... ] Up to date
[ o.k. ] Checking git sources [ linux-mainline linux-4.14.y ]
[ .... ] Up to date
[ o.k. ] Checking git sources [ arm-trusted-firmware-sunxi-mainline allwinner-stable ]
[ .... ] Fetching updates
fatal: Couldn't find remote ref allwinner-stable
[ .... ] Checking out
error: pathspec 'FETCH_HEAD' did not match any file(s) known to git.
[ o.k. ] Checking git sources [ sunxi-tools master ]
[ .... ] Up to date
[ o.k. ] Checking git sources [ rkbin-tools master ]
[ .... ] Up to date
[ o.k. ] Checking git sources [ marvell-tools A3700_utils-armada-17.10 ]
[ .... ] Up to date
[ o.k. ] Checking git sources [ odroidc2-blobs master ]
[ .... ] Up to date
[ o.k. ] Cleaning output/debs for [ nanopineo2 next ]
[ o.k. ] Cleaning [ arm-trusted-firmware-sunxi-mainline/allwinner-stable ]
[ o.k. ] Compiling ATF
[ o.k. ] Compiler version [ aarch64-linux-gnu-gcc 6.4.1 ]
[ o.k. ] Started patching process for [ atf sunxi64-nanopineo2-next ]
[ o.k. ] Looking for user patches in [ userpatches/atf/atf-sunxi64 ]
[ warn ] * [l][c] add-SRAM-mapping-for-SCPI.patch [ failed ]
[ warn ] * [l][c] enable-a53-errata-workaround.patch [ failed ]
[ warn ] * [l][c] enable-additional-regulators.patch [ failed ]
[ warn ] * [l][c] set-rsb-to-nonsec.patch [ failed ]
make: *** No rule to make target 'bl31'.  Stop.
[ error ] ERROR in function compile_atf [ compilation.sh:59 ]
[ error ] ATF compilation failed
[ o.k. ] Process terminated
root@ImageBuilder:/srv/build#
Can someone point me in the proper direction? I have been using the builder for custom images for other boards without error.
I will also say, I love this tool. Makes it very easy for me to build customized Armbian images with my applications pre-installed.
Thanks, Steve
Well that was fast. I retried the build and saw a change had been committed to the repository. It's building now.
Thanks SO much!
Steve
