Upgrade Error with Armbian 5.00 on Cubieboard2 running from NAND
Hi there
Please confirm if other have seen this as well, I can create a small bug report if this is indeed a mistake in the upgrade scripts...
Yes, I can confirm, I observed the very same behavior!
I had the problem of a bricked Cubie before, see my posts above, and I was able to reanimate it with Igor's help. At that time I just realized that something had gone wrong during the update, the uImage was missing, despite the fact that there's plenty of room on the NAND (I'm even using a 16G Cubie).
Now, couple of months later I did an update again that came with a kernel (and presumably with some firmware) update. And bang, this also failed like the time before:
Preparing to unpack .../linux-jessie-root-cubietruck_5.16_armhf.deb ...
mv: cannot move ‘/boot/bin’ to ‘/boot/bin.old/bin’: Directory not empty
Unpacking linux-jessie-root-cubietruck (5.16) over (5.11) ...
dpkg: error processing archive /var/cache/apt/archives/linux-jessie-root-cubietruck_5.16_armhf.deb (--unpack):
 unable to make backup link of `./boot/bin/bananapi.bin' before installing new version: Operation not permitted
Processing triggers for systemd (215-17+deb8u4) ...
Processing triggers for man-db (2.7.0.2-5) ...
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
somebody@cubietruck:~$
Take note of the line "mv: cannot move ‘/boot/bin’ to ‘/boot/bin.old/bin’: Directory not empty"
At that time I was already clairaudient due to previous experiences. And, yes, a short glance at /boot revealed me the the very same situation like on your cubie, an existent, incomplete /boot/bin.old, a wrong /boot/bin.old/bin inside and a missing uImage - No chance to survive a reboot. And I did what you did, rename /boot/bin.old and relaunch the update, this time successfully:
Setting up linux-firmware-image-sun7i (5.16) ...
Setting up linux-headers-sun7i (5.16) ...
Compiling headers - please wait ...
Setting up linux-image-sun7i (5.16) ...
Image Name:   Linux kernel
Created:      Sat Jul 30 15:02:29 2016
Image Type:   ARM Linux Kernel Image (uncompressed)
Data Size:    5605944 Bytes = 5474.55 kB = 5.35 MB
Load Address: 40008000
Entry Point:  40008000
Now I had a Kernel uImage again and after a final reboot the Cubie came up back without a hitch:
  ____      _     _      _                   _
 / ___|   _| |__ (_) ___| |_ _ __ _   _  ___| | __
| |  | | | | '_ \| |/ _ \ __| '__| | | |/ __| |/ /
| |__| |_| | |_) | |  __/ |_| |  | |_| | (__|   <
 \____\__,_|_.__/|_|\___|\__|_|   \__,_|\___|_|\_\
Welcome to ARMBIAN Debian GNU/Linux 8 (jessie) 3.4.112-sun7i
System load:   4.85             Up time:       1 min
Memory usage:  5 % of 1998Mb    IP:            192.168.xxx.xxx 192.168.xxx.xxx
CPU temp:      39°C             HDD temp:      34°C
Usage of /:    24% of 15G       storage/:      50% of 3.6T
So, yes, could you please create a small bug report. This is clearly reproducible and should be easily fixable.
