I can't get my Orange Pi working... After writing image to a SD card, the system boots up and the green LED lights up. Everything looks ok, until "Starting kernel..." line. After that the screen goes all black or displays artifacts. I tried different HDMI cables but still same issues. I've been trying with 5.25, 5.30, 5.35, 5.38 Ubuntu versions. I found out that the only way to get the system up and running was installing version 5.30, because the system boots with 720p mode. Other builds use 1080p mode. However when I "apt upgrade" the kernel, system boots with 1080p and the issue shows up again. Is there a way to "force" Armbian to use 720p mode by default?
