I've formatted the opi+2 card I have using recovery and now I get ping screen. I use a 1280x1024 screen with a DVI converter. I tried the HDMI cable using a 1080p TV and it worked without issues.  I also tried "h3disp -m 33 -d" "h3dsip -m 1024x768 -d" "h3disp -m 33" and so on. None of them worked.
Here is a system output (used armbianmonitor -u)
http://ix.io/1iWN
I noticed this output when used dmesg command:
 [DISP] disp_ioctl,line:1584:para err in disp_ioctl, cmd = 0x0,screen id = 65536
Debian Next Image works nicely BUT I need a desktop and I can't see "Install Desktop" section on the armbian-config. And you need to fix the mainline kernel bug.
EDIT
Upgraded the system, and now I can see "Install Desktop" option. Thanks goes to you!
