alterfritz Posted August 6, 2018 Posted August 6, 2018 Hi, need some help here. I'm running an orangepiwin: root@orangepiwin:~# uname -a Linux orangepiwin 3.10.107-pine64 #11 SMP PREEMPT Sun Feb 11 19:22:44 CET 2018 aarch64 aarch64 aarch64 GNU/Linux I try to use it for my 3d printers, by using a thing like octoprint or repetier server. I woud prefer repetier as due to its smaller footprint. I have issues to etsablish usb communication - it works fine on raspbrian on an rasppi3, so I guess the printer(s) are fine. I think this is related to the USB communication, I can see that the printer is detected. root@orangepiwin:~# ls -la /dev/ttyU* crw-rw---- 1 root dialout 188, 0 Aug 6 07:32 /dev/ttyUSB0 I can also connect from repetier server and can see the output of the console about marlin fw. However I can not move the axis in any direction or home the printer with G28. Seems I can not talk to the printer from armbian. I also tried this: usermod -a -G dialout repetierserver No effect - I uploaded armbianmonitor -u here http://ix.io/1jiP Somebody have any idea what I can try next? Thanks! Regards Joerg
alterfritz Posted August 6, 2018 Author Posted August 6, 2018 [ 9.414921] hub 2-1:1.0: 4 ports detected [ 9.433218] sunxi_i2c_do_xfer()902 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x19) [ 9.452863] sunxi_i2c_do_xfer()902 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x19) [ 9.472566] sunxi_i2c_do_xfer()902 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x8) [ 9.492228] sunxi_i2c_do_xfer()902 - [i2c1] incomplete xfer (status: 0x20, ... maybe thats the reason?
alterfritz Posted August 6, 2018 Author Posted August 6, 2018 Sorry... that seems to be related to i2c...
alterfritz Posted August 6, 2018 Author Posted August 6, 2018 Issue can be closed... work now. It was - shame on me - the long USB cable. I did not looked at it as it works perfectly under Windows. I switched to a short one... works!
