Hi, At the beginning I would like to emphasize that I am not an expert in linux :) I use bananapi m2 + v1.1 in my project. Until now everything worked well with the SD card on armbian 5.25. My project is now finished and would like to run the system from emmc. I used armbian-config to move system from SD card to emmc. I chose the only option: Boot from eMMc – system on eMMC. Everything went well except the message (while formatting):
EXT4-fs (mmcblk1p1): Unrecognized mount option "compress-force=zlib" or missing value
mount: wrong fs type, bad option, bad superblock on /dev/mmcblk1p1,
       missing codepage or helper program, or other error
       In some cases useful info is found in syslog - try
       dmesg | tail or so.
After removing the SD card, system does not start, it always stops at the same point.
I connected the serial debug and here's what I received:
U-Boot SPL 2017.11-armbian (Jan 24 2018 - 22:08:56)
DRAM: 1024 MiB
Trying to boot from MMC2
U-Boot 2017.11-armbian (Jan 24 2018 - 22:08:56 +0100) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Banana Pi BPI-M2-Plus
DRAM:  1 GiB
MMC:   SUNXI SD/MMC: 0, SUNXI SD/MMC: 1
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
USB2:   USB EHCI 1.00
USB3:   USB OHCI 1.0
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 2 for devices... 1 USB Device(s) found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc1(part 0) is current device
Scanning mmc 1:1...
2092 bytes read in 204 ms (9.8 KiB/s)
Booting from eMMC or secondary SD
MMC: no card present
mmc_init: -123, time 2
(The last two sequences repeated several times) and next:
Device 0: device type unknown
... is now current device
** Bad device usb 0 **
No ethernet found.
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
(The last three sequences repeated several times) and next:
Config file not found
No ethernet found.
No ethernet found.
When I insert the SD card everything works as always. I can mount / dev / mmcblk1p1 and it looks like the directory structure has been copied correctly. I have two BananaPi’s  boards and both behave the same way. So it's probably not a hardware issue. I searched the forum and did not find a solution to this problem.
Anyway, has  someone any Ideas to get the EMMc working?
Problem solved. I downloaded the latest version of Armbian. In this version, the system transfer from sd to emmc worked as expected.
