Minty Posted September 19, 2018 Share Posted September 19, 2018 I successfully installed the rtl-sdr and Gqrx on a pine a64 with Armbian, it works perfectly Now I want to make an IMSI catcher (just beacons with gr-gsm), which I did on another ubuntu device. I first had problems with pip and then changed the export path. Now this works but I have problems installing PyBombs: sudo pip install PyBOMBS I get: Command "/usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-FNJDtY/ruamel.ordereddict/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-QjKLMX/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-install-FNJDtY/ruamel.ordereddict/ Thanks for any advice Link to comment Share on other sites More sharing options...
Minty Posted September 19, 2018 Author Share Posted September 19, 2018 Okay, got it to work. For other newbies like me: I created a virtual environment with python 3.6 https://askubuntu.com/questions/865554/how-do-i-install-python-3-6-using-apt-get Then, I installed python-dev and it worked. Link to comment Share on other sites More sharing options...
