How to fix/survive a broken sudo
sudo: /usr/bin/sudo must be owned by uid 0 and have the setuid bit set
That kind of problem.
Option 1
Control + Alt + F3
log in as root  and live without sudo
Option 2
Open a terminal
ssh root@127.0.0.1
and log in as root
Option 3
copy this to a file named /tmp/armbiansudo.txt
chown root:root /usr/bin/sudo
chmod 4755 /usr/bin/sudo
chown root:root /usr/lib/sudo/sudoers.so
chmod 4755 /usr/lib/sudo/sudoers.so
chown root:root /etc/sudoers
chown root:root /etc/sudoers.d /etc/sudoers.d/README  /var/lib/sudo
And now  follow option 1 or option 2 and type this on a root term
bash  /tmp/armbiansudo.txt
I think  sudo gave me problems in the past, I suspect it was behind some permissions problems that made me reinstall the OS, so i would recommend option 1 or option 2, I tried option 3 to test if the fix still worked before post it here, I would post here if I have problems again.
