MarkChang Posted October 3, 2018 Posted October 3, 2018 Dear all, i have been using Armbian bionic currently running kernel 4.4.156-rockchip64, for sharing files over the internet, i am currently using sshfs. Openssl benchmark ls as followed OpenSSL 1.1.0g 2 Nov 2017 built on: reproducible build, date unspecified options:bn(64,64) rc4(char) des(int) aes(partial) blowfish(ptr) compiler: gcc -DDSO_DLFCN -DHAVE_DLFCN_H -DNDEBUG -DOPENSSL_THREADS -DOPENSSL_NO_STATIC_ENGINE -DOPENSSL_PIC -DOPENSSL_BN_ASM_MONT -DSHA1_ASM -DSHA256_ASM -DSHA512_ASM -DVPAES_ASM -DECP_NISTZ256_ASM -DPOLY1305_ASM -DOPENSSLDIR="\"/usr/lib/ssl\"" -DENGINESDIR="\"/usr/lib/aarch64-linux-gnu/engines-1.1\"" The 'numbers' are in 1000s of bytes per second processed. type 16 bytes 64 bytes 256 bytes 1024 bytes 8192 bytes 16384 bytes aes-256-cbc 89554.02k 252995.50k 458589.18k 588922.54k 641851.39k 637659.82k However, when it comes to sshfs speeds, i can only reach around 20-25MBytes per second > fallocate -l 1G /tmp/largefile > pv /tmp/largefile > /srv/tmp/test_largefile 1.00GiB 0:00:46 [22.0MiB/s] [==============================================================================================================================================>] 100% Do i need AF_ALG to actually speedup sshfs speed? or is this board not fast enough to achieve higher sshfs speeds? Note : the cpu loading is not that high on sshfs copying Thanks a lot for your help
jmandawg Posted October 8, 2018 Posted October 8, 2018 over scp, i average around 30-35MBs: root@chromebox:/home/jmandawg# scp random500MBfile renegade:/mnt/data/ root@renegade's password: random500MBfile 100% 500MB 31.5MB/s 00:15
