golom Posted October 7, 2018 Posted October 7, 2018 I'm using a NanoPI NEO (v1.31 Lite, 512M RAM) which has an Allwinner H3 cpu; running Armbian Stretch from here: https://www.armbian.com/nanopi-neo/ When changing the init system from the default systemd to sysV init as described at http://without-systemd.org/wiki/index.php/How_to_remove_systemd_from_a_Debian_Stretch_installation on the next boot, the boot process freezes. Installing the package sysvinit-core conflicts with systemd-sysv, depending on which resolution I choose (install systemd-shim and some libraries, or remove systemd-sysv and NetworkManager), the boot process freezes at one of the following 3 lines: [....] Starting OpenBSD Secure Shell server: sshd. ok [....] Setting sysfs variables.... ok [....] Starting network connection manager: NetworkManager. ok As this is after the bootloader, the initramfs, the kernel and the init process, I'm not sure on how to fix this. I tried the process of flashing, apt update/upgrade and install sysvinit-core several times, the freezes are always there. Any ideas on what to try, how to avoid the freezes or how to fix this?
