Did a fresh armbian install on odroid HC2 board/ updated etc...Im getting this in my syslog.  It looks its complaining about ntpd.  (Unexpected origin timestamp 0xdf6c1697.9f8452c6 and Unexpected origin timestamp 0xdf6c1697.9f8452c6
Is this a know issue or something that could be ignored?
Thanks,
Oct 13 09:01:03 localhost ntpd[1115]: receive: Unexpected origin timestamp 0xdf6c1697.9f8452c6 does not match aorg 0000000000.00000000 from server@193.2.120.3 xmt 0xdf6c16af.0ea2342a
Oct 13 09:01:03 localhost systemd[1]: Time has been changed
Oct 13 09:01:03 localhost ntpd[1115]: receive: Unexpected origin timestamp 0xdf6c1697.9f883569 does not match aorg 0000000000.00000000 from server@213.250.32.3 xmt 0xdf6c16af.10a38b03
Oct 13 09:01:03 localhost systemd[1]: apt-daily.timer: Adding 11h 9min 10.258246s random time.
Oct 13 09:01:03 localhost systemd[1]: apt-daily-upgrade.timer: Adding 27min 36.829351s random time.
Oct 13 09:01:31 localhost systemd[1]: Created slice User Slice of root.
Oct 13 09:01:31 localhost systemd[1]: Starting User Manager for UID 0...
Oct 13 09:01:31 localhost systemd[1]: Started Session 2 of user root.
Oct 13 09:01:31 localhost systemd[1445]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Oct 13 09:01:31 localhost systemd[1445]: Listening on GnuPG network certificate management daemon.
Oct 13 09:01:31 localhost systemd[1445]: Reached target Paths.
Oct 13 09:01:31 localhost systemd[1445]: Listening on GnuPG cryptographic agent (access for web browsers).
Oct 13 09:01:31 localhost systemd[1445]: Reached target Timers.
Oct 13 09:01:31 localhost systemd[1445]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Oct 13 09:01:31 localhost systemd[1445]: Listening on GnuPG cryptographic agent and passphrase cache.
Oct 13 09:01:31 localhost systemd[1445]: Reached target Sockets.
Oct 13 09:01:31 localhost systemd[1445]: Reached target Basic System.
Oct 13 09:01:31 localhost systemd[1445]: Reached target Default.
Oct 13 09:01:31 localhost systemd[1445]: Startup finished in 157ms.
Oct 13 09:01:31 localhost systemd[1]: Started User Manager for UID 0.
Oct 13 09:05:01 localhost CRON[1801]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Oct 13 09:06:05 localhost ntpd[1115]: kernel reports TIME_ERROR: 0x41: Clock Unsynchronized
Oct 13 09:06:30 localhost ntpd[1867]: ntpd 4.2.8p10@1.3728-o Sun Feb 25 22:00:44 UTC 2018 (1): Starting
Oct 13 09:06:30 localhost ntpd[1867]: Command line: ntpd version
Oct 13 09:06:30 localhost ntpd[1869]: proto: precision = 3.583 usec (-18)
Oct 13 09:06:30 localhost ntpd[1869]: unable to bind to wildcard address :: - another process may be running - EXITING
