I've been getting a journal file full of this kind of entry lately, which is using up all my memory until I get an error "no space left on device". I have two Cubietrucks, this is only occurring on one of them, both running mainline kernel and both up to date.
The one causing problems has a 2.5" hdd mounted via the sata connector.
Oct 16 11:27:35 stpeter.nentura liblogging-stdlog[1048]: action 'action 12' resumed (module 'builtin:omfile') [v8.24.0 try http://www.rsyslog.com/e/2359 ]
Oct 16 11:27:35 stpeter.nentura liblogging-stdlog[1048]: action 'action 2' suspended, next retry is Tue Oct 16 11:28:05 2018 [v8.24.0 try http://www.rsyslog.com/e/2007 ]
I've seen on the link http://www.rsyslog.com/e/2007 that there is a "how to solve it" but I'm a bit lost.
A frequent case for this error message on Debian-based distributions (like raspbian) is that rsyslog.conf contains the instruction to write to the xconsole pipe, but this pipe is never read. If so, you can simply delete these lines to remove the error message. These lines are usually found at the end of rsyslog.conf.
Can someone help dignose and solve?
Thanks!
