 I've just tried mainline kernel 4.19 with my two TV boxes and first impression is wow! it works!  It's faster than expected! Thanks!
With Magicsee N5 I can't access the internal eMMC. I use factory bootloder, meson-gxl-s905x-p212 dtb, released 4.19 kernel.
I got:
root@lepotato:~# dmesg|grep mmc
[    0.000000] Kernel command line: console=ttyAML0,115200 root=/dev/mmcblk0p2
[    0.979648] meson-gx-mmc d0070000.mmc: Linked as a consumer to regulator.2
[    0.985812] meson-gx-mmc d0070000.mmc: Linked as a consumer to regulator.1
[    0.992676] meson-gx-mmc d0070000.mmc: Dropping the link to regulator.1
[    0.999184] meson-gx-mmc d0070000.mmc: Dropping the link to regulator.2
[    1.005962] meson-gx-mmc d0072000.mmc: Linked as a consumer to regulator.2
[    1.012580] meson-gx-mmc d0072000.mmc: Linked as a consumer to regulator.1
[    1.019383] meson-gx-mmc d0072000.mmc: Got CD GPIO
[    1.050790] meson-gx-mmc d0074000.mmc: Linked as a consumer to regulator.4
[    1.052173] meson-gx-mmc d0074000.mmc: Linked as a consumer to regulator.1
[    1.058938] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
[    1.100626] mmc0: new high speed SDHC card at address 0001
[    1.107836] mmcblk0: mmc0:0001 SD8GB 7.28 GiB
[    1.122762]  mmcblk0: p1 p2
[    1.694717] meson-gx-mmc d0070000.mmc: Linked as a consumer to regulator.2
[    1.700530] meson-gx-mmc d0070000.mmc: Linked as a consumer to regulator.1
[    1.707411] meson-gx-mmc d0070000.mmc: Dropping the link to regulator.1
[    1.713888] meson-gx-mmc d0070000.mmc: Dropping the link to regulator.2
[    1.737590] meson-gx-mmc d0070000.mmc: Linked as a consumer to regulator.2
[    1.738912] meson-gx-mmc d0070000.mmc: Linked as a consumer to regulator.1
[    1.745766] meson-gx-mmc d0070000.mmc: Dropping the link to regulator.1
[    1.752240] meson-gx-mmc d0070000.mmc: Dropping the link to regulator.2
[    1.759846] meson-gx-mmc d0070000.mmc: Linked as a consumer to regulator.2
[    1.765629] meson-gx-mmc d0070000.mmc: Linked as a consumer to regulator.1
[    1.772497] meson-gx-mmc d0070000.mmc: Dropping the link to regulator.1
[    1.778990] meson-gx-mmc d0070000.mmc: Dropping the link to regulator.2
[    1.833559] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: (null)
[    2.193186] meson-gx-mmc d0070000.mmc: Linked as a consumer to regulator.2
[    2.198747] meson-gx-mmc d0070000.mmc: Linked as a consumer to regulator.1
[    2.205782] meson-gx-mmc d0070000.mmc: Dropping the link to regulator.1
[    2.212138] meson-gx-mmc d0070000.mmc: Dropping the link to regulator.2
[    2.627095] meson-gx-mmc d0070000.mmc: Linked as a consumer to regulator.2
[    2.629932] meson-gx-mmc d0070000.mmc: Linked as a consumer to regulator.1
[    2.636841] meson-gx-mmc d0070000.mmc: Dropping the link to regulator.1
[    2.643348] meson-gx-mmc d0070000.mmc: Dropping the link to regulator.2
[    4.942703] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
[    5.641638] meson-gx-mmc d0070000.mmc: Linked as a consumer to regulator.2
[    5.641745] meson-gx-mmc d0070000.mmc: Linked as a consumer to regulator.1
[    5.641821] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
[    5.697460] mmc2: queuing unknown CIS tuple 0x01 (3 bytes)
[    5.708349] mmc2: queuing unknown CIS tuple 0x1a (5 bytes)
[    5.713097] mmc2: queuing unknown CIS tuple 0x1b (8 bytes)
[    5.714044] mmc2: queuing unknown CIS tuple 0x14 (0 bytes)
[    5.716514] mmc2: queuing unknown CIS tuple 0x80 (1 bytes)
[    5.716561] mmc2: queuing unknown CIS tuple 0x81 (1 bytes)
[    5.716607] mmc2: queuing unknown CIS tuple 0x82 (1 bytes)
[    5.716638] mmc2: new high speed SDIO card at address 0001
[  242.654386] Workqueue: events_freezable mmc_rescan
[  242.654487]  mmc_wait_for_req_done+0x44/0x160
[  242.654497]  mmc_wait_for_req+0x98/0xd4
[  242.654505]  mmc_send_tuning+0x11c/0x1b8
[  242.654521]  meson_mmc_execute_tuning+0x6c/0x20c
[  242.654531]  mmc_execute_tuning+0x48/0xbc
[  242.654543]  mmc_init_card+0x9f0/0x19c4
[  242.654554]  mmc_attach_mmc+0xac/0x170
[  242.654564]  mmc_rescan+0x394/0x3cc
SDcard is recognized and works but internal one is didn't. How I can access the internal eMMC? Why I got mmc_rescan hints periodically ?
My second box is Beelink MiniMX. GBit phy is initialized but there is no link ... - I use the standard meson-gxbb-p201.dtb. I need to change something in the device-tree?
bets regards, Gabor
 ok, I had to half the frequency in the device-tree. mmcblk1 mmcblkboot0, mmcblkboot1, mmcblkgp0 and mmcblkrpmb have appeared.
How can I access the system,logo,env ...etc partitions ?
In earlier kernel logs (4.12) I found:
[    3.369031] mmcblk0: emmc:0001 AWPD3R 14.6 GiB
[    3.377416] mmcblk0boot0: emmc:0001 AWPD3R partition 1 4.00 MiB
[    3.383431] mmcblk0boot1: emmc:0001 AWPD3R partition 2 4.00 MiB
[    3.385447] mmcblk0rpmb: emmc:0001 AWPD3R partition 3 4.00 MiB
[    3.392229] Enter aml_emmc_partition_ops
[    3.395735] [mmc_read_partition_tbl] mmc read partition OK!
[    3.400990] add_emmc_partition
[    3.404385] [mmcblk0p01]           bootloader  offset 0x000000000000, size 0x000000400000
[    3.412716] [mmcblk0p02]             reserved  offset 0x000002400000, size 0x000004000000
[    3.421077] [mmcblk0p03]                cache  offset 0x000006c00000, size 0x000020000000
[    3.429441] [mmcblk0p04]                  env  offset 0x000027400000, size 0x000000800000
[    3.437806] [mmcblk0p05]                 logo  offset 0x000028400000, size 0x000002000000
[    3.446176] [mmcblk0p06]             recovery  offset 0x00002ac00000, size 0x000002000000
[    3.454532] [mmcblk0p07]                  rsv  offset 0x00002d400000, size 0x000000800000
[    3.462900] [mmcblk0p08]                  tee  offset 0x00002e400000, size 0x000000800000
[    3.471284] [mmcblk0p09]                crypt  offset 0x00002f400000, size 0x000002000000
[    3.479641] [mmcblk0p10]                 misc  offset 0x000031c00000, size 0x000002000000
[    3.488001] [mmcblk0p11]            instaboot  offset 0x000034400000, size 0x000020000000
[    3.496370] [mmcblk0p12]                 boot  offset 0x000054c00000, size 0x000002000000
[    3.504732] [mmcblk0p13]               system  offset 0x000057400000, size 0x000040000000
[    3.513100] [mmcblk0p14]                 data  offset 0x000097c00000, size 0x00030c200000
[    3.521334] amlmmc_dtb_init: register dtb chardev
[    3.526130] amlmmc_dtb_init: register dtb chardev OK
[    3.531101] Exit aml_emmc_partition_ops OK.
Is it removed from the latest kernels?
best regards, Gabor
Try to run fdisk /dev/mmcblk0 and then issue the command p to take a look to the real partitions on the device
Hi jock,
thank you for your answer! I realized that partitions defined in the factory dtb. I'm using the mainline dtb so I had to define with the blkdevparts. Now I can access factory partitions with mainline kernel...
best regards, Gabor
