hello
I have installed legacy jessie server on my orangepi pc and I am trying to make a 3g usb modem work
I have installed usb-modeswitch but it seems that my usb modem is not switched to modem state
the modem is a k3806-z with vendor id 19d2 and product id 1013
when i plug it on my desktop linux pc (fedora) it gets switched to product id 1015
but this does not happen in the orangepi
is there anything that I should do for modeswitching to work ?
I think "modemmanager" have nothing to do with your problem I mean switching .... and if your modem is not in modemswitch DB you can add rule manually
thank you for your contribution
well while having only usb-modeswitch installed the mode switching was not working
after installing modemmanager it worked
i did not have to do any manual configuration
perhaps installing this package added some usb-modeswitch entries so that no manual entry was required
i do not really know
the fact though is that now the 3g modem is usable :)
may be this one https://github.com/digidietze/usb-modeswitch-data/blob/master/usb_modeswitch.d/19d2:1013
found it googling  "usb_modeswitch 19d2 1013" .....
you can test it if you have "spare" linux box or SD card :)
my linux box has this rule too ...  (slackware 14.0)
cat /usr/share/usb_modeswitch/19d2:1013
# Vodafone (ZTE) K3806-Z
TargetVendor=  0x19d2
TargetProduct= 0x1015
MessageContent="5553424312345678000000000000061b000000020000000000000000000000"
NeedResponse=1
NoDriverLoading=1
I added this config in a debian 8.3 live
root@debian:~# cat /etc/usb_modeswitch.d/19d2\:1013
NeedResponse=1
NoDriverLoading=1
but after plugging in the modem it did not change mode
then I installed modemmanager and modeswitching to 19d2:1015 worked without any config changes
then I removed modemmanager and modeswitching stopped working again
It really seems that this package is required for this specific usb modem to work
