gnubie Posted November 25, 2018 Share Posted November 25, 2018 First up, I did have a good dig around but couldn't find anything discussing my problem but if there is a thread already existing please just link to it, no need to get huffy. I have a problem with armbian on NanoPi NEO where USB devices are not properly detected at start up (warm or cold start). Armbian version details: BOARD=nanopineo BOARD_NAME="NanoPi Neo" BOARDFAMILY=sun8i VERSION=5.67.181115 LINUXFAMILY=sunxi BRANCH=next ARCH=arm IMAGE_TYPE=nightly BOARD_TYPE=conf INITRD_ARCH=arm KERNEL_IMAGE_TYPE=zImage I have also tried nightly build Armbian_5.65_Nanopineo_Debian_stretch_next_4.14.78.img. The problem as seen from syslog: Nov 26 08:29:20 localhost kernel: [ 3.093697] usb 6-1: new full-speed USB device number 2 using ohci-platform Nov 26 08:29:20 localhost kernel: [ 3.285722] usb 6-1: device descriptor read/64, error -62 Nov 26 08:29:20 localhost kernel: [ 3.585689] usb 6-1: device descriptor read/64, error -62 Nov 26 08:29:20 localhost kernel: [ 3.881816] usb 6-1: new full-speed USB device number 3 using ohci-platform Nov 26 08:29:20 localhost kernel: [ 4.073774] usb 6-1: device descriptor read/64, error -62 Nov 26 08:29:20 localhost kernel: [ 4.373768] usb 6-1: device descriptor read/64, error -62 Nov 26 08:29:20 localhost kernel: [ 4.481838] usb usb6-port1: attempt power cycle Nov 26 08:29:20 localhost kernel: [ 4.985772] usb 6-1: new full-speed USB device number 4 using ohci-platform Nov 26 08:29:20 localhost kernel: [ 5.401757] usb 6-1: device not accepting address 4, error -62 Nov 26 08:29:20 localhost kernel: [ 5.589770] usb 6-1: new full-speed USB device number 5 using ohci-platform Nov 26 08:29:20 localhost kernel: [ 6.005759] usb 6-1: device not accepting address 5, error -62 Nov 26 08:29:20 localhost kernel: [ 6.005887] usb usb6-port1: unable to enumerate USB device I am attempting to connect a USB hard disk to the NanoPi NEO and have it mounted via fstab at boot. The problem occurs with either a bus powered USB hard disk (Toshiba brand) but also using a separately powered USB SATA bridge. Once armbian has completed boot and I can logon, plugging in the USB disk drives shows them correctly detected and they can be manually mounted. The problem does not occur when using nanopi-neo-core_sd_friendlycore-xenial_4.14_armhf_20181011.img from friendlyarm download site. Any suggestions as to how to fix this? Please do not say "it's your power supply". Power supply is not the problem. Link to comment Share on other sites More sharing options...
