Hi all,
I've come upon a weird thing and I wanted to verify that I don't so something wrong.
I've build a custom kernel module which is a PWM led device with an SPI interface. If I use the spidev,
then everything works fine and I'm able to control the led. But when I'm using a custom device-tree
and load the module then when I'm calling the `spi_write()` function then I'm getting an error (-22).
The external device is actually an arduino nano that implements an I2C IIO light measurement device, using
a dual light dependent resistor. Also I'm using the SPI channel to drive a led using PWM. It's very
straight-forward and everything seems to be working, except the SPI driver. You can find the sources here.
Also the SBC I'm using is the nanopi-neo.
I thought that I was doing something wrong, but I've also tried with one of the mainline standard drivers,
like the leds-dac124s085 driver and I get the same error.
The device tree I'm using is this one and my armbianEnv.txt content is this:
overlay_prefix=sun8i-h3
overlays=usbhost1 usbhost2 i2c0 spi-add-cs1 spi-ardled
Of course, I've added my `sun8i-h3-spi-ardled` in the /boot/dtb/overlay folder and u-boot loads it without errors.
When the kernel boots, I can see the led device and when I'm trying to write the PWM value in the brightness,
with this command:
echo 10 > /sys/bus/spi/devices/spi0.0/leds/ardled-0/brightness
Then the driver prints this in the dmesg
[Jan 2 14:19] ardled: loading out-of-tree module taints kernel.
[  +0.002445] Arduino PWM LED ardled-0 registered
[Jan 2 14:20] ardled set: 10, ret: -22
[  +0.000015] bus_num: 0
              bits_per_word: 16
              chip_select: 0
              mode: 0
              max_speed_hz: 1000000
[  +0.000014] leds ardled-0: Setting an LED's brightness failed (-22)
The same goes with also the default mainline `leds-dac124s085` driver which also uses SPI to drive 4 leds, instead of one.
Also, I've probed the SPI mosi and clk and there's no any activity when the SPI is used in the modules. But, I can see the
proper signals when I'm using the spidev. No need to say, that when I'm using spidev or the module I'm only loading the
proper overlay in the armbianEnv.txt and not both of them.
Does anyone knows why spidev works but any other SPI driver doesn't?
Thanks.
P.S. Also, I've found out that armbian-config installs an older version of the linux-kernel. The kernel version is:
Linux nanopineo 4.14.91-sunxi
But the kernel sources are older:
/usr/src/linux-headers-4.14.84-sunxi
Therefore, I had to cross-build the modules using the armbian sources on my workstation in `armbian/build/cache/sources/linux-mainline/linux-4.14.y`
