No bluetooth device in my Armbian...
Banana Pi M2+
ARMBIAN 5.65 stable Ubuntu 18.04.1 LTS 4.14.84-sunxi
dpkg-query -Wf '${Version}\n' bluez
5.48-0ubuntu3.1
No Bluetooth device(hci0):
rfkill list
0: phy0: Wireless LAN
        Soft blocked: no
        Hard blocked: no
Which refers to the error:
systemctl status ap6212-bluetooth.service
● ap6212-bluetooth.service - LSB: Patch firmware for ap6212 adapter
   Loaded: loaded (/etc/init.d/ap6212-bluetooth; generated)
   Active: failed (Result: exit-code) since Tue 2019-01-08 09:18:38 UTC; 1min 2s ago
     Docs: man:systemd-sysv-generator(8)
  Process: 2553 ExecStart=/etc/init.d/ap6212-bluetooth start (code=exited, status=1/FAILURE)
Jan 08 09:18:28 bananapim2plus systemd[1]: Starting LSB: Patch firmware for ap6212 adapter...
Jan 08 09:18:38 bananapim2plus ap6212-bluetooth[2553]: Initialization timed out.
Jan 08 09:18:38 bananapim2plus ap6212-bluetooth[2553]: bcm43xx_init
Jan 08 09:18:38 bananapim2plus ap6212-bluetooth[2553]: Can't get device info: No such device
Jan 08 09:18:38 bananapim2plus systemd[1]: ap6212-bluetooth.service: Control process exited, code=exite
Jan 08 09:18:38 bananapim2plus systemd[1]: ap6212-bluetooth.service: Failed with result 'exit-code'.
Jan 08 09:18:38 bananapim2plus systemd[1]: Failed to start LSB: Patch firmware for ap6212 adapter.
In the scrip this command failed:
hciattach /dev/ttyS1 bcm43xx 115200 flow bdaddr 43:29:B1:55:01:01
bcm43xx_init
Can you help me?
Thanks,
gemesif
