gemesif Posted January 8, 2019 Share Posted January 8, 2019 Hello, No bluetooth device in my Armbian... Banana Pi M2+ ARMBIAN 5.65 stable Ubuntu 18.04.1 LTS 4.14.84-sunxi dpkg-query -Wf '${Version}\n' bluez 5.48-0ubuntu3.1 No Bluetooth device(hci0): rfkill list 0: phy0: Wireless LAN Soft blocked: no Hard blocked: no Which refers to the error: systemctl status ap6212-bluetooth.service ● ap6212-bluetooth.service - LSB: Patch firmware for ap6212 adapter Loaded: loaded (/etc/init.d/ap6212-bluetooth; generated) Active: failed (Result: exit-code) since Tue 2019-01-08 09:18:38 UTC; 1min 2s ago Docs: man:systemd-sysv-generator(8) Process: 2553 ExecStart=/etc/init.d/ap6212-bluetooth start (code=exited, status=1/FAILURE) Jan 08 09:18:28 bananapim2plus systemd[1]: Starting LSB: Patch firmware for ap6212 adapter... Jan 08 09:18:38 bananapim2plus ap6212-bluetooth[2553]: Initialization timed out. Jan 08 09:18:38 bananapim2plus ap6212-bluetooth[2553]: bcm43xx_init Jan 08 09:18:38 bananapim2plus ap6212-bluetooth[2553]: Can't get device info: No such device Jan 08 09:18:38 bananapim2plus systemd[1]: ap6212-bluetooth.service: Control process exited, code=exite Jan 08 09:18:38 bananapim2plus systemd[1]: ap6212-bluetooth.service: Failed with result 'exit-code'. Jan 08 09:18:38 bananapim2plus systemd[1]: Failed to start LSB: Patch firmware for ap6212 adapter. In the scrip this command failed: hciattach /dev/ttyS1 bcm43xx 115200 flow bdaddr 43:29:B1:55:01:01 bcm43xx_init Initialization timed out. Can you help me? Thanks, gemesif Link to comment Share on other sites More sharing options...
gemesif Posted January 10, 2019 Author Share Posted January 10, 2019 Hello, What do you recommend? How can I solve my problem? Thanks, gemesif Link to comment Share on other sites More sharing options...
