malaga Posted January 26, 2019 Posted January 26, 2019 dear community i am so glad to be here on this great forum - this is a great place. i have installed Armbian on a. banana pi b. orange-pi and futhermore i will try to install it on Udoo Quad at the moment i am workin on a new plan: i am planning a Wi-Fi controlled rc-car using Arduino UNO, ESP8266 Websockets or UDP the question that arises here. how would you decide? i want to create an Arduino project about a Wi-Fi controlled (ESP8266) RC car using. - with a tight budget you can’t really buy everything you need at once. what is needed: An Arduino UNO An ESP8266 An L298N motor driver - with or without H-bridge An LF33CV 3.3V regulator An RC car Also batteries that meet your needs / much better: a power-pack regarding the protocolls - not yet every decision is made: - which protocol should i use!? - WebSocket protocol or UDP-protocoll? i need to figure out what else is needed to run this project with ESP8266 / NodeMCU one. what is WebSocket Protocol? Quote WebSockets are a bi-directional, full-duplex, persistent connection from a web browser to a server. Once a WebSocket connection is established the connection stays open until the client or server decides to close this connection. With this open connection, the client or server can send a message at any given time to the other. Expand guess that i first will try out to go with the WebSocket-approach but furthermore: well after setting up all with a WebSocket-approach i afterwards will also try controlling the car with other protocols like HTTP or UDP to see the difference, if any. what do you think?
