dan1234 Posted February 14, 2019 Posted February 14, 2019 (edited) Hello! In this topic: It was confirmed that more than 1 pin GPIO can be used for 1-wire bus. How can I edit or create my sun8i-h3-w1-gpio.dts for this? Spoiler /dts-v1/; /plugin/; / { compatible = "allwinner,sun8i-h3"; fragment@0 { target = <&pio>; __overlay__ { w1_pins: w1_pins { pins = "PD14"; function = "gpio_in"; }; }; }; fragment@1 { target-path = "/"; __overlay__ { onewire@0 { compatible = "w1-gpio"; pinctrl-names = "default"; pinctrl-0 = <&w1_pins>; gpios = <&pio 3 14 0>; /* PD14 */ status = "okay"; }; }; }; }; Can anyone give an example? Thank you in advance! Edited February 14, 2019 by dan1234
dan1234 Posted February 14, 2019 Author Posted February 14, 2019 If I change sun8i-h3-w1-gpio.dts as follows: /dts-v1/; /plugin/; / { compatible = "allwinner,sun8i-h3"; fragment@0 { target = <&pio>; __overlay__ { w1_pins: w1_pins { pins = "PA20" ,"PA10"; functions = "gpio_in"; }; }; }; fragment@1 { target-path = "/"; __overlay__ { onewire@0 { compatible = "w1-gpio"; pinctrl-names = "default"; pinctrl-0 = <&w1_pins>; gpios = <&pio 0 20 0>, <&pio 0 10 0>; status = "okay"; }; }; }; }; That as 1-wire bus works only the first pin (PA20) from the specified. The second pin (PA10) is not working as 1-wire bus. What am I doing wrong?
