hi freinds
i'm trying to use a dht22  to read temperature and humidity ,
with Armbian 5.65 (stretch) 4.14.78-sunxi and orenge pi zero
orange pi state like this
/etc/modules-load.d/modules.conf
#gpio sunxi
#gc2035 wire
wl-sunxi
wl-gpio
wl-therm
#sunxi-cir
#xradio_wlan
g_serial
#xradio_wlan
i2c -dev
/etc/default/cpufrequtils
ENABLE=true
MIN SPEED=6000000
MAX_SPEED=1200000
GOVERNOR=interactive
/boot/armbianEnv.txt
verbosity=1
logo=disabled
console=both
disp_mode=1920x1080p60
overlay prefix=sun8i-h3
overlays=usbhost2 usbhost3 12c0 wl-gpio
rootdev=WID=55cee3e8-79d6-4dd3-ab14-99274fo626cb
rootfstype=ext4
param wl_pin=PA10
param wl_pin
int_pullup=1
usbstorageguirks=0x2537:0x1066:u,0x2537:0x1068:u
and im trying with this code
https://www.piprojects.xyz/temperature-sensor-orange-pi-python-code/
and
https://community.home-assistant.io/t/extend-dht-sensor-for-orange-pi/39838
from pyA20.gpio import gpio
from pyA20.gpio import port
#import RPi.GPIO as GPIO
import dht22
import time
import datetime
# initialize GPIO
#gpio.setwarnings(False)
#gpio.setmode(GPIO.BCM)
PIN2 = port.PA6
gpio.init()
#gpio.cleanup()
# read data using pin 14
instance = dht22.DHT22(pin=PIN2)
while True:
    result = instance.read()
    if result.is_valid():
        print("Last valid input: " + str(datetime.datetime.now()))
        print("Temperature: %.2f C" % result.temperature)
        print("Humidity: %.2f %%" % result.humidity)
    time.sleep(1)
dht22 work correct with raspberry and rasbian
also test ds18b20 with orange pi and work good but i need humidity sensor
i dont know what's the problem??!!
Thanks for any help
You have a problem with the dht22 working. You never specify what the problem actually is. What's the error code you're getting?
Ima go ahead and take a wild guess that you don't initiate a configuration for that port.
put the following after gpio.init()
PIN2 =gpio.setcfg(PIN2, gpio.OUTPUT)
i dont have any error
the output is nothing and "time.sleep(1)" is runs.
the code is here
https://github.com/ionutpi/DHT22-Python-library-Orange-PI
defined in >>dht22.py
in class DHT22
import time
#import RPi
class DHT22Result:
    'DHT22 sensor result returned by DHT22.read() method'
    ERR_NO_ERROR = 0
    ERR_MISSING_DATA = 1
    ERR_CRC = 2
    error_code = ERR_NO_ERROR
    temperature = -1
    humidity = -1
    def __init__(self, error_code, temperature, humidity):
        self.error_code = error_code
        self.temperature = temperature
        self.humidity = humidity
    def is_valid(self):
        return self.error_code == DHT22Result.ERR_NO_ERROR
class DHT22:
    'DHT22 sensor reader class for Raspberry'
    __pin = 0
    def __init__(self, pin):
        self.__pin = pin
    def read(self):
        gpio.setcfg(self.__pin, gpio.OUTPUT)
        # send initial high
        self.__send_and_sleep(gpio.HIGH, 0.05)
        # pull down to low
        self.__send_and_sleep(gpio.LOW, 0.02)
        # change to input using pull up
        #gpio.setcfg(self.__pin, gpio.INPUT, gpio.PULLUP)
	gpio.setcfg(self.__pin, gpio.INPUT)
	gpio.pullup(self.__pin, gpio.PULLUP)
        # collect data into an array
        data = self.__collect_input()
        # parse lengths of all data pull up periods
        pull_up_lengths = self.__parse_data_pull_up_lengths(data)
        # if bit count mismatch, return error (4 byte data + 1 byte checksum)
        if len(pull_up_lengths) != 40:
            return DHT22Result(DHT22Result.ERR_MISSING_DATA, 0, 0)
Got this same wrapper, as well as others to work on an NPiNeo and an OPiZ recently (defining outside ) but you're right it's prolly redundant.
I got it working using this wrapper (forked/updated within 1 year opposed to 2yr on the one u link to) https://github.com/jingl3s/DHT11-DHT22-Python-library-Orange-PI and the following script.
What happens when you print(instance) after it's defined?
import dht
import time
import datetime
# initialize GPIO
temPin = port.PG11
trigPin = port.PG7
gpio.init()
gpio.setcfg(trigPin, gpio.OUTPUT)
instance = dht.DHT(pin=temPin, sensor=22)
def tempOut():
    celToFar = result.temperature * 1.8 + 32
    print("Celsius: {0:0.1f} C".format(result.temperature))
    print("Fahrenheit: {0:0.1f} F".format(celToFar))
    print("Humidity: {0:0.1f} %%".format(result.humidity))
    print("\n")
def trigPinState(trigPin):
    trigState = gpio.input(trigPin) # What is state of trigger pin?
    if trigState == 0: #Then it's low
        return 'Low: %s' % trigState
    elif trigState == 1: # then its high
        return 'High: %s' % trigState
    else:
        print('error!)
while True:
        tempOut()
        if celToFar < 75:
            gpio.output(trigPin, gpio.HIGH)
        elif celToFar > 75:
            gpio.output(trigPin, gpio.LOW)
    time.sleep(.2)
thanks your answer
i changed gpio like
# initialize GPIO
temPin = port.PA13
trigPin = port.PA14
when run program , say error
root@orangepizero:-/orangepi_PC_gpio_py113/MiT22-Python-library-Orange-PI# sudo python dht3 .py
File ''dht3 . py
a , line 32 print ( ' error ! )
Synt axError : EOL while scanning string literal
edit line 32 ('error!')
and then
root@orangepizero:-/DHT22-master# sudo python dht3.py
Last valid input: 2018-10-28 20:52:24.470819
Celsius: 26.5 C
Fahrenheit: 79.7 F
Humidity: 45.2 %%
Traceback (most recent call last):
File 'dht3.py', line 38, in <module>
if celToFar < 75: NameError: name 'celToFar' is not defined
i have question
what's trigPin and what to do this pin?
The script I gave you was a very loose example and it includes things I was using for my specific project. Things that you don't necessarily need to use for your own.
trigPin in this situation is just an 'empty' pin that I use as an LED trigger. If temperature is above X, turn on LED. If temp below X, turn LED off.
If you just want a temp and humidity readout, remove every function, set pins how you'd like and just print tempOut()
Then go here: https://www.codecademy.com/learn/learn-python
Or here: https://www.codewars.com/?language=python
Or here: https://www.youtube.com/watch?v=apACNr7DC_s
