halim Posted February 15, 2019 Posted February 15, 2019 Hi, After upgrade from xenial to bionic we found a problem with R1 internal WIFI. First connection to any wireless network with nmtui works wihout problem. But after that if we try to switch to another wireless network it fails. It doesn't even reconnect to the first network ever. If we plug in an external usb wifi adapter(which uses a different driver than the internal wifi driver) it works without problem as expected. What do you think ? Have you experienced the same problem ever ? What is wrong with the internal wifi ? It was working good in xenial. I blacklisted the internal driver and using external wifi adapter for now. "wlan0" in the logs might belong to external wifi adapter I can reproduce this problem easily and provide any logs you want. Thank you http://ix.io/1B6e Description: Ubuntu 18.04.2 LTS Release: 18.04 Codename: bionic 4.19.20-sunxi #5.75 SMP Sat Feb 9 19:02:47 CET 2019 armv7l
halim Posted February 17, 2019 Author Posted February 17, 2019 Can anyone with a Orange Pi R1 confirm the problem ?
Rik Posted May 22, 2019 Posted May 22, 2019 If I'm not too late, I too have this issue with OPi R1, but I'm using Armbian Stretch 5.83. I found a (very bad) workaround: rmmod 8189es; modprobe 8189es I think there is something wrong with this driver, but I did not investigate further. Hope this can help.
