domoticity Posted February 25, 2019 Share Posted February 25, 2019 Hy again :p; I have customed my sd for my tinkerboard. i have done some settings like eth0 in static, partitions modified scripts and hostapd. When i put it in another Tinkerboard, everything works except wifi ap. I have searched why, and i have found that in my initial tinkerboard wifi is wlan0 and his settings is in /etc/network/interfaces.d/armbian.ap.nat When i put my SD in another tinkerboard, it is wlan1 which mounts and no wlan0. Wlan1 has no ip address. i don't see where is the problem? thanks by advance Link to comment Share on other sites More sharing options...
domoticity Posted February 26, 2019 Author Share Posted February 26, 2019 Hy I answer myself :) I have found what's going wrong. tinkerboard register the interfaces in this files /etc/udev/rules.d/70-persistent-net.rule When the eth0 is already used, the next mac adress takes eth1. So the solution: delete this files /etc/udev/rules.d/70-persistent-net.rule 2 Link to comment Share on other sites More sharing options...
