yogggoy Posted March 4, 2019 Posted March 4, 2019 Hello. I'am try use adv7604 and csi in orangepi zero +2 H5, and i cant understand right way to apply changes in build-framework. After all settings in menuconfig are selected, i save cfg in .config_adv7604, and Exit from menuconfig. Build-fwk continued to buld my img ~1hour, and after that i cannot found the module adv7604.ko. OK I am rebuild img again, in the menuconfig i save settings in .config and again cannot find modules. Оn the third try it finally turned out. I saved the config several times in .config (maybe, rewrite old cfg file) and modules now is available in system. It is possible, add .config-files select mode in build-framework? Or maybe it is already available?
