Matthai Posted March 10, 2019 Posted March 10, 2019 I have OrangePi Zero 512 with Armbian Bionic. I hav econnected LED diode to GPIO PA12 pin. When I (re)boot the device, LED is automatically on. I have to switch it off then manually (with Python script). Is there any config file in Armbian to define which GPIO ports should be switched off?
nerkn Posted December 23, 2020 Posted December 23, 2020 could you find any solution? I'm trying to use motor driver, forward and backward is on by default.
