txumino Posted October 16, 2016 Share Posted October 16, 2016 First of all forgive my English, I do not speak the language and certainly make mistakes. use google translator to write;-) I have the Orange Pi + 2e and I installed "Debian Jessie," but I can not run the wifi that is integrated, I am new to linux, so everything costs me more. According to the specifications https://linux-sunxi.org/Orange_Pi_Plus_2E the wifi chip is Realtek RTL8189FTV Would appreciate some help, thank you very much. Link to comment Share on other sites More sharing options...
tkaiser Posted October 16, 2016 Share Posted October 16, 2016 Please provide the output of 'lsmod'. If there is no '8189fs' listed then please try a 'modprobe 8189fs' and then follow these instructions here: https://github.com/igorpecovnik/lib/issues/493#issuecomment-252751466 Please report back whether it works and if you do not succeed we need the output from 'dmesg' 1 Link to comment Share on other sites More sharing options...
txumino Posted October 16, 2016 Author Share Posted October 16, 2016 Please provide the output of 'lsmod'. If there is no '8189fs' listed then please try a 'modprobe 8189fs' and then follow these instructions here: https://github.com/igorpecovnik/lib/issues/493#issuecomment-252751466 Please report back whether it works and if you do not succeed we need the output from 'dmesg' Thanks for the reply, I have done what you mention, when intengo enabled connection in nmtui, out error. I leave here what you ask: root@orangepiplus2e:~# lsmod Module Size Used by sunxi_cir 1601 0 8189fs 1050491 0 root@orangepiplus2e:~# login as: root root@192.168.1.102's password: ___ ____ _ ____ _____ / _ \ _ __ __ _ _ __ __ _ ___ | _ \(_) _ |___ \| ____| | | | | '__/ _` | '_ \ / _` |/ _ \ | |_) | |_| |_ __) | _| | |_| | | | (_| | | | | (_| | __/ | __/| |_ _| / __/| |___ \___/|_| \__,_|_| |_|\__, |\___| |_| |_| |_| |_____|_____| |___/ Welcome to ARMBIAN Debian GNU/Linux 8 (jessie) 3.4.112-sun8i System load: 0.30 Up time: 7 min Memory usage: 3 % of 2013Mb IP: 192.168.1.102 CPU temp: 52°C Usage of /: 86% of 1.5G Last login: Sun Oct 16 11:40:03 2016 from 192.168.1.2 root@orangepiplus2e:~# dmesg [ 0.000000] Booting Linux on physical CPU 0 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 3.4.112-sun8i (root@xenial) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.1) ) #14 SMP PREEMPT Wed Sep 14 20:29:31 CEST 2016 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: sun8i [ 0.000000] cma: CMA: reserved 256 MiB at b0000000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] On node 0 totalpages: 524288 [ 0.000000] free_area_init_node: node 0, pgdat c0a24900, node_mem_map c0b5d000 [ 0.000000] Normal zone: 1710 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 192850 pages, LIFO batch:31 [ 0.000000] HighMem zone: 2898 pages used for memmap [ 0.000000] HighMem zone: 326830 pages, LIFO batch:31 [ 0.000000] script_init enter! [ 0.000000] script_init exit! [ 0.000000] PERCPU: Embedded 8 pages/cpu @c1d7a000 s11968 r8192 d12608 u32768 [ 0.000000] pcpu-alloc: s11968 r8192 d12608 u32768 alloc=8*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 519680 [ 0.000000] Kernel command line: console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 cgroup_enable=memory swapaccount=1 sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_no_mali_mem_reserve sunxi_fb_mem_reserve=16 panic=10 consoleblank=0 enforcing=0 loglevel=1 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] allocated 4194304 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Memory: 2048MB = 2048MB total [ 0.000000] Memory: 1796504k/1796504k available, 300648k reserved, 1056768K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) [ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc095bce8 (9552 kB) [ 0.000000] .init : 0xc095c000 - 0xc09aeec0 ( 332 kB) [ 0.000000] .data : 0xc09b0000 - 0xc0a29750 ( 486 kB) [ 0.000000] .bss : 0xc0a29f04 - 0xc0b5cf90 (1229 kB) [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] Additional per-CPU info printed with stalls. [ 0.000000] NR_IRQS:544 [ 0.000000] Architected local timer running at 24.00MHz. [ 0.000000] Switching to timer-based delay loop [ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms [ 0.000000] Console: colour dummy device 80x30 [ 0.000000] console [tty1] enabled [ 0.000272] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000) [ 0.000296] pid_max: default: 32768 minimum: 301 [ 0.000635] Mount-cache hash table entries: 512 [ 0.001603] Initializing cgroup subsys cpuacct [ 0.001618] Initializing cgroup subsys memory [ 0.001665] Initializing cgroup subsys devices [ 0.001676] Initializing cgroup subsys freezer [ 0.001687] Initializing cgroup subsys blkio [ 0.001710] Initializing cgroup subsys perf_event [ 0.001792] CPU: Testing write buffer coherency: ok [ 0.001837] ftrace: allocating 25740 entries in 76 pages [ 0.030293] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.030311] [sunxi_smp_prepare_cpus] enter [ 0.030347] Setting up static identity map for 0x40691938 - 0x40691990 [ 0.031292] CPU1: Booted secondary processor [ 0.031292] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.031425] CPU2: Booted secondary processor [ 0.031425] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002 [ 0.040487] CPU3: Booted secondary processor [ 0.040487] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003 [ 0.040607] Brought up 4 CPUs [ 0.040607] SMP: Total of 4 processors activated (19200.00 BogoMIPS). [ 0.040899] devtmpfs: initialized [ 0.050883] wakeup src cnt is : 2. [ 0.050897] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000 [ 0.050908] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x0 [ 0.050918] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40 [ 0.050929] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000 [ 0.050940] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x8 [ 0.050950] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40 [ 0.050961] sunxi pm init [ 0.051098] pinctrl core: initialized pinctrl subsystem [ 0.061107] NET: Registered protocol family 16 [ 0.062330] DMA: preallocated 2048 KiB pool for atomic coherent allocations [ 0.062397] script_sysfs_init success [ 0.062425] sunxi_dump_init success [ 0.063305] gpiochip_add: registered GPIOs 0 to 383 on device: sunxi-pinctrl [ 0.063305] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver [ 0.063305] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.063305] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.063305] script config pll_video to 297 Mhz [ 0.063305] script config pll_de to 864 Mhz [ 0.063305] script config pll_ve to 402 Mhz [ 0.063305] sunxi_default_clk_init [ 0.063305] try to set pll6ahb1 to 200000000 [ 0.063305] try to set ahb clk source to pll6ahb1 [ 0.063305] set ahb clk source to pll6ahb1 [ 0.063305] try to set ahb1 to 200000000 [ 0.063305] try to set apb1 to 100000000 [ 0.070236] bio: create slab <bio-0> at 0 [ 0.070310] [ARISC] :sunxi-arisc driver v1.04 [ 0.091742] [ARISC] :arisc version: [v0.1.58] [ 0.182011] [ARISC] :sunxi-arisc driver v1.04 startup succeeded [ 0.183606] SCSI subsystem initialized [ 0.183606] usbcore: registered new interface driver usbfs [ 0.183606] usbcore: registered new interface driver hub [ 0.183606] usbcore: registered new device driver usb [ 0.183606] twi_chan_cfg()340 - [twi0] has no twi_regulator. [ 0.183606] twi_chan_cfg()340 - [twi1] has no twi_regulator. [ 0.183606] twi_chan_cfg()340 - [twi2] has no twi_regulator. [ 0.183606] Linux video capture interface: v2.00 [ 0.183606] Advanced Linux Sound Architecture Driver Version 1.0.25. [ 0.183606] cfg80211: Calling CRDA to update world regulatory domain [ 0.183606] Switching to clocksource arch_sys_counter [ 0.193959] FS-Cache: Loaded [ 0.194244] CacheFiles: Loaded [ 0.205372] NET: Registered protocol family 2 [ 0.216591] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.217190] TCP established hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.218950] TCP bind hash table entries: 65536 (order: 7, 786432 bytes) [ 0.220040] TCP: Hash tables configured (established 131072 bind 65536) [ 0.220052] TCP: reno registered [ 0.220066] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.220104] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.220457] NET: Registered protocol family 1 [ 0.220869] RPC: Registered named UNIX socket transport module. [ 0.220881] RPC: Registered udp transport module. [ 0.220889] RPC: Registered tcp transport module. [ 0.220897] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.221085] Trying to unpack rootfs image as initramfs... [ 0.407549] Freeing initrd memory: 3040K [ 0.408093] hw perfevents: enabled with ARMv7 Cortex_A7 PMU driver, 5 counters available [ 0.408218] sunxi_reg_init enter [ 0.409130] audit: initializing netlink socket (disabled) [ 0.409180] type=2000 audit(0.400:1): initialized [ 0.410471] highmem bounce pool size: 64 pages [ 0.411350] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.411538] misc fatfs initialized [ 0.412261] NFS: Registering the id_resolver key type [ 0.412633] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.412647] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 0.413413] NTFS driver 2.1.30 [Flags: R/W]. [ 0.413731] fuse init (API version 7.18) [ 0.414491] Btrfs loaded [ 0.414515] msgmni has been set to 1450 [ 0.415924] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) [ 0.415946] io scheduler noop registered [ 0.415956] io scheduler deadline registered [ 0.416028] io scheduler cfq registered (default) [ 0.416432] [DISP]disp_module_init [ 0.416743] cmdline,init_disp= [ 0.416772] cmdline,disp= [ 0.425708] [DISP] Fb_map_kernel_logo,line:932:Fb_map_kernel_logo failed! [ 0.442109] Console: switching to colour frame buffer device 160x45 [ 0.459402] [DISP]disp_module_init finish [ 0.459624] sw_uart_get_devinfo()1503 - uart0 has no uart_regulator. [ 0.459937] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI [ 0.459950] sw_uart_pm()890 - uart0 clk is already enable [ 0.459968] sw_console_setup()1233 - console setup baud 115200 parity n bits 8, flow n [ 0.460438] console [ttyS0] enabled [ 0.460991] sunxi_cmatest_init enter [ 0.461029] sunxi_cmatest_init success [ 0.465140] brd: module loaded [ 0.469020] loop: module loaded [ 0.469318] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator. [ 0.469333] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator. [ 0.469916] spi spi0: master is unqueued, this is deprecated [ 0.470288] tun: Universal TUN/TAP device driver, 1.6 [ 0.470299] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com> [ 0.471606] PPP generic driver version 2.4.2 [ 0.471798] PPP BSD Compression module registered [ 0.471809] PPP Deflate Compression module registered [ 0.474574] PPP MPPE Compression module registered [ 0.474592] NET: Registered protocol family 24 [ 0.474668] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.494775] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.494810] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1 [ 0.495388] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000 [ 0.510036] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00 [ 0.510683] hub 1-0:1.0: USB hub found [ 0.510708] hub 1-0:1.0: 1 port detected [ 0.531076] sunxi-ehci sunxi-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.531107] sunxi-ehci sunxi-ehci.2: new USB bus registered, assigned bus number 2 [ 0.531531] sunxi-ehci sunxi-ehci.2: irq 106, io mem 0xf1c1b000 [ 0.550034] sunxi-ehci sunxi-ehci.2: USB 0.0 started, EHCI 1.00 [ 0.550571] hub 2-0:1.0: USB hub found [ 0.550595] hub 2-0:1.0: 1 port detected [ 0.570961] sunxi-ehci sunxi-ehci.3: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.570989] sunxi-ehci sunxi-ehci.3: new USB bus registered, assigned bus number 3 [ 0.571387] sunxi-ehci sunxi-ehci.3: irq 108, io mem 0xf1c1c000 [ 0.590035] sunxi-ehci sunxi-ehci.3: USB 0.0 started, EHCI 1.00 [ 0.590571] hub 3-0:1.0: USB hub found [ 0.590591] hub 3-0:1.0: 1 port detected [ 0.610950] sunxi-ehci sunxi-ehci.4: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.610979] sunxi-ehci sunxi-ehci.4: new USB bus registered, assigned bus number 4 [ 0.611373] sunxi-ehci sunxi-ehci.4: irq 110, io mem 0xf1c1d000 [ 0.630030] sunxi-ehci sunxi-ehci.4: USB 0.0 started, EHCI 1.00 [ 0.630573] hub 4-0:1.0: USB hub found [ 0.630592] hub 4-0:1.0: 1 port detected [ 0.630969] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 0.651065] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 0.651094] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 5 [ 0.651126] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400 [ 0.714546] hub 5-0:1.0: USB hub found [ 0.714566] hub 5-0:1.0: 1 port detected [ 0.734934] sunxi-ohci sunxi-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 0.734963] sunxi-ohci sunxi-ohci.2: new USB bus registered, assigned bus number 6 [ 0.734995] sunxi-ohci sunxi-ohci.2: irq 107, io mem 0xf1c1b400 [ 0.794576] hub 6-0:1.0: USB hub found [ 0.794600] hub 6-0:1.0: 1 port detected [ 0.814976] sunxi-ohci sunxi-ohci.3: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 0.815004] sunxi-ohci sunxi-ohci.3: new USB bus registered, assigned bus number 7 [ 0.815036] sunxi-ohci sunxi-ohci.3: irq 109, io mem 0xf1c1c400 [ 0.874566] hub 7-0:1.0: USB hub found [ 0.874586] hub 7-0:1.0: 1 port detected [ 0.894978] sunxi-ohci sunxi-ohci.4: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 0.895006] sunxi-ohci sunxi-ohci.4: new USB bus registered, assigned bus number 8 [ 0.895038] sunxi-ohci sunxi-ohci.4: irq 111, io mem 0xf1c1d400 [ 0.954539] hub 8-0:1.0: USB hub found [ 0.954559] hub 8-0:1.0: 1 port detected [ 0.954920] Initializing USB Mass Storage driver... [ 0.955149] usbcore: registered new interface driver usb-storage [ 0.955159] USB Mass Storage support registered. [ 0.955215] usbcore: registered new interface driver ums-alauda [ 0.955262] usbcore: registered new interface driver ums-cypress [ 0.955317] usbcore: registered new interface driver ums-datafab [ 0.955369] usbcore: registered new interface driver ums_eneub6250 [ 0.955416] usbcore: registered new interface driver ums-freecom [ 0.955465] usbcore: registered new interface driver ums-isd200 [ 0.955511] usbcore: registered new interface driver ums-jumpshot [ 0.955557] usbcore: registered new interface driver ums-karma [ 0.955604] usbcore: registered new interface driver ums-onetouch [ 0.955664] usbcore: registered new interface driver ums-realtek [ 0.955715] usbcore: registered new interface driver ums-sddr09 [ 0.955764] usbcore: registered new interface driver ums-sddr55 [ 0.955813] usbcore: registered new interface driver ums-usbat [ 0.956028] uinput result 0 , vmouse_init [ 0.956632] mousedev: PS/2 mouse device common for all mice [ 0.956855] sunxikbd_init failed. [ 0.957360] ls_fetch_sysconfig_para: type err device_used = -1073060220. [ 0.957612] =========script_get_err============ [ 0.957622] ltr_init: ls_fetch_sysconfig_para err. [ 0.957933] [RTC] WARNING: Rtc time will be wrong!! [ 0.957943] [RTC] WARNING: use *internal OSC* as clock source [ 0.958191] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0 [ 0.958240] i2c /dev entries driver [ 0.958633] IR RC5(x) protocol handler initialized [ 0.958760] sunxi cedar version 0.1 [ 0.958806] [cedar]: install start!!! [ 0.959000] [cedar]: install end!!! [ 0.959234] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x18) [ 0.959404] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x19) [ 0.959572] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x1a) [ 0.959740] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x29) [ 0.959907] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2a) [ 0.960090] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2b) [ 0.960259] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4c) [ 0.960427] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4d) [ 0.960594] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4e) [ 0.960793] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x18) [ 0.960988] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x19) [ 0.961182] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1a) [ 0.961377] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x29) [ 0.961572] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2a) [ 0.961766] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2b) [ 0.961961] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4c) [ 0.962156] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4d) [ 0.962351] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4e) [ 0.962366] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0 [ 0.962527] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbf [ 0.962704] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0) [ 0.962717] wdt_enable, write reg 0xf1c20cb8 val 0x00000000 [ 0.962728] timeout_to_interv, line 167 [ 0.962736] interv_to_timeout, line 189 [ 0.962745] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec [ 0.963158] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com [ 0.963373] calibrat: max_cpufreq 1296Mhz Type 0! [ 0.963685] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.111 2015-4-13 15:24) Compiled in Sep 14 2016 at 20:28:08 [ 0.963721] [mmc]: get mmc0's sdc_power is null! [ 0.963750] [mmc]: get mmc1's sdc_power is null! [ 0.963759] [mmc]: get mmc1's 2xmode ok, val = 1 [ 0.963768] [mmc]: get mmc1's ddrmode ok, val = 1 [ 0.963797] [mmc]: get mmc2's sdc_power is null! [ 0.963806] [mmc]: get mmc2's 2xmode ok, val = 1 [ 0.963816] [mmc]: get mmc2's ddrmode ok, val = 1 [ 0.963828] [mmc]: MMC host used card: 0x7, boot card: 0x5, io_card 2 [ 0.964873] [mmc]: sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 0.965985] [mmc]: sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 0.966557] [mmc]: sdc2 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 0.967525] [mmc]: sdc0 power_supply is null [ 0.968995] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 0.971814] no blue_led, ignore it! [ 0.972066] Registered led device: red_led [ 0.972179] Registered led device: green_led [ 0.972196] no led_0, ignore it! [ 0.972203] no led_1, ignore it! [ 0.972210] no led_2, ignore it! [ 0.972217] no led_3, ignore it! [ 0.972224] no led_4, ignore it! [ 0.972231] no led_5, ignore it! [ 0.972238] no led_6, ignore it! [ 0.972245] no led_7, ignore it! [ 0.973066] usbcore: registered new interface driver usbhid [ 0.973076] usbhid: USB HID core driver [ 0.978302] asoc: sndcodec <-> sunxi-codec mapping ok [ 0.979176] [DAUDIO]sunxi-daudio cannot find any using configuration for controllers, return directly! [ 0.979363] [I2S]snddaudio cannot find any using configuration for controllers, return directly! [ 0.979377] [DAUDIO0] driver not init,just return. [ 0.980090] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 0.983163] asoc: sndhdmi <-> sunxi-hdmiaudio.0 mapping ok [ 0.984286] oprofile: using arm/armv7-ca7 [ 0.984478] u32 classifier [ 0.984486] Performance counters on [ 0.984493] input device check on [ 0.984500] Actions configured [ 0.984687] IPv4 over IPv4 tunneling driver [ 0.985312] TCP: bic registered [ 0.985323] TCP: cubic registered [ 0.985331] TCP: westwood registered [ 0.985338] TCP: highspeed registered [ 0.985346] TCP: hybla registered [ 0.985353] TCP: htcp registered [ 0.985360] TCP: vegas registered [ 0.985368] TCP: veno registered [ 0.985375] TCP: scalable registered [ 0.985383] TCP: lp registered [ 0.985390] TCP: yeah registered [ 0.985397] TCP: illinois registered [ 0.985405] Initializing XFRM netlink socket [ 0.985646] NET: Registered protocol family 10 [ 0.986811] NET: Registered protocol family 17 [ 0.986841] NET: Registered protocol family 15 [ 0.986890] Registering the dns_resolver key type [ 0.987360] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 [ 0.987382] ThumbEE CPU extension supported. [ 0.987404] Registering SWP/SWPB emulation handler [ 0.987974] registered taskstats version 1 [ 0.988432] cmdline,disp= [ 0.988744] [HDMI] power vcc-hdmi-18 [ 1.001717] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 1.004230] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 1.009541] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 1.009656] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 1.012152] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 1.019447] ths_fetch_sysconfig_para: type err device_used = 1. [ 1.020765] CPU Budget:corekeeper enabled [ 1.020994] CPU Budget:Register notifier [ 1.021007] CPU Budget:register Success [ 1.021019] sunxi-budget-cooling sunxi-budget-cooling: Cooling device registered: thermal-budget-0 [ 1.024211] [rf_pm]: module power0 name vcc-wifi-33 [ 1.024225] [rf_pm]: failed to fetch module_power0_vol [ 1.024235] [rf_pm]: mod has no chip_en gpio [ 1.024243] [rf_pm]: regulator on. [ 1.024258] [rf_pm]: set losc_out 32k out[wifi_pm]: wifi gpio init is OK !! [ 1.024595] [rfkill]: init no bt used in configuration [ 1.024607] ALSA device list: [ 1.024615] #0: audiocodec [ 1.024623] #1: sndhdmi [ 1.025512] Freeing init memory: 328K [ 1.031637] [mmc]: sdc0 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 1.033036] [mmc]: sdc0 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B [ 1.033147] [mmc]: sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B [ 1.033299] [mmc]: sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B [ 1.033396] mmc0: new high speed SDHC card at address b368 [ 1.033978] mmcblk0: mmc0:b368 00000 7.51 GiB [ 1.035999] mmcblk0: p1 [ 1.036693] mmcblk mmc0:b368: Card claimed for testing. [ 1.036711] mmc0:b368: 00000 7.51 GiB [ 1.036757] *******************sd init ok******************* [ 1.036782] [mmc]: sdc2 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 1.038344] [mmc]: sdc2 power_supply is null [ 1.050080] [mmc]: sdc2 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 1.071798] [mmc]: sdc2 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 1.071945] systemd-udevd[98]: starting version 215 [ 1.074380] [mmc]: sdc2 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 1.082999] [mmc]: sdc2 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 1.083468] [mmc]: sdc2 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 1.083587] [mmc]: sdc2 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 1.083707] [mmc]: sdc2 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 1.086213] [mmc]: sdc2 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 1.101372] [mmc]: sdc2 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 1.113541] [mmc]: sdc2 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 1.114077] [mmc]: sdc2 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 1.114290] [mmc]: sdc2 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 1.114436] [mmc]: sdc2 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing MMC-HS(SDR20) dt B [ 1.114523] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing MMC-HS(SDR20) dt B [ 1.114637] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing MMC-HS(SDR20) dt B [ 1.114781] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing MMC-HS(SDR20) dt B [ 1.115022] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing MMC-HS(SDR20) dt B [ 1.115157] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.115260] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.115388] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.115547] mmc1: new high speed DDR MMC card at address 0001 [ 1.116237] mmcblk1: mmc1:0001 AWPD3R 14.5 GiB [ 1.116542] mmcblk1boot0: mmc1:0001 AWPD3R partition 1 4.00 MiB [ 1.116847] mmcblk1boot1: mmc1:0001 AWPD3R partition 2 4.00 MiB [ 1.118612] mmcblk1: p1 [ 1.119935] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.121728] mmcblk1boot1: unknown partition table [ 1.122685] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.123840] mmcblk1boot0: unknown partition table [ 1.124186] mmcblk mmc1:0001: Card claimed for testing. [ 1.124206] mmc1:0001: AWPD3R 14.5 GiB [ 1.124260] *******************mmc init ok ******************* [ 1.151256] mmcblk0: r/w command failed, status = 0x80000900 [ 1.151280] end_request: I/O error, dev mmcblk0, sector 15759096 [ 1.151300] Buffer I/O error on device mmcblk0, logical block 1969887 [ 1.201297] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.233136] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.233987] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.234428] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.234705] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.235079] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.235401] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.235880] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.236204] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.236585] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.236908] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.237283] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.237635] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.237947] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.238272] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.238760] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.239059] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.239424] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.239707] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.240173] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.240454] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.240827] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.241159] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.241473] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.241761] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.245552] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.245965] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.246348] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.246785] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.247161] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.247507] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.247828] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.248188] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.248467] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.248856] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.249161] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.249523] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.249833] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.250281] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.250585] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.250877] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.251166] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.251447] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.251724] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.251999] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.252273] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.252550] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.252823] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.253111] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.253405] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.253698] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.253998] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.254290] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.254578] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.254858] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.255136] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.255411] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.255685] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.255972] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.256254] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.256528] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.256809] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.257090] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.257378] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.257659] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.257941] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.258243] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.258529] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.258817] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.259108] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.259518] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.259843] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 1.620048] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device0, type=4, mode=5 [ 2.107505] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 2.113860] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 4.917440] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) [ 6.160328] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR) [ 6.160667] systemd[1]: Detected architecture 'arm'. [ 6.167222] systemd[1]: Set hostname to <orangepiplus2e>. [ 6.286911] mmcblk0: r/w command failed, status = 0x80000900 [ 6.286933] end_request: I/O error, dev mmcblk0, sector 53320 [ 6.293138] EXT4-fs error (device mmcblk0p1): ext4_find_entry:941: inode #1283: comm systemd-sysv-ge: reading directory lblock 0 [ 6.611811] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory. [ 6.614492] systemd[1]: Starting Forward Password Requests to Wall Directory Watch. [ 6.614849] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 6.614927] systemd[1]: Expecting device dev-ttyS0.device... [ 6.615511] systemd[1]: Starting Remote File Systems (Pre). [ 6.615900] systemd[1]: Reached target Remote File Systems (Pre). [ 6.616057] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point. [ 6.616970] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 6.617071] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch. [ 6.617279] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 6.617338] systemd[1]: Starting Paths. [ 6.617665] systemd[1]: Reached target Paths. [ 6.617735] systemd[1]: Starting Encrypted Volumes. [ 6.618071] systemd[1]: Reached target Encrypted Volumes. [ 6.618139] systemd[1]: Starting Root Slice. [ 6.618549] systemd[1]: Created slice Root Slice. [ 6.618610] systemd[1]: Starting User and Session Slice. [ 6.619086] systemd[1]: Created slice User and Session Slice. [ 6.619147] systemd[1]: Starting /dev/initctl Compatibility Named Pipe. [ 6.619720] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [ 6.619782] systemd[1]: Starting Delayed Shutdown Socket. [ 6.620288] systemd[1]: Listening on Delayed Shutdown Socket. [ 6.620358] systemd[1]: Starting Journal Socket (/dev/log). [ 6.620849] systemd[1]: Listening on Journal Socket (/dev/log). [ 6.620938] systemd[1]: Starting udev Control Socket. [ 6.621352] systemd[1]: Listening on udev Control Socket. [ 6.621429] systemd[1]: Starting udev Kernel Socket. [ 6.621822] systemd[1]: Listening on udev Kernel Socket. [ 6.621907] systemd[1]: Starting Journal Socket. [ 6.622358] systemd[1]: Listening on Journal Socket. [ 6.622479] systemd[1]: Starting System Slice. [ 6.622955] systemd[1]: Created slice System Slice. [ 6.623070] systemd[1]: Started File System Check on Root Device. [ 6.623124] systemd[1]: Starting system-serial\x2dgetty.slice. [ 6.623712] systemd[1]: Created slice system-serial\x2dgetty.slice. [ 6.623773] systemd[1]: Starting system-getty.slice. [ 6.624272] systemd[1]: Created slice system-getty.slice. [ 6.624402] systemd[1]: Starting Increase datagram queue length... [ 6.690879] systemd[1]: Starting Restore / save the current clock... [ 6.774776] systemd[1]: Started Set Up Additional Binary Formats. [ 6.774907] systemd[1]: Starting udev Coldplug all Devices... [ 6.840954] systemd[1]: Mounting POSIX Message Queue File System... [ 6.910580] systemd[1]: Mounted Huge Pages File System. [ 6.911140] systemd[1]: Starting Create list of required static device nodes for the current kernel... [ 6.955539] systemd[1]: Starting Load Kernel Modules... [ 7.011265] systemd[1]: Mounting Debug File System... [ 7.125702] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 7.127259] [mmc]: sdc1 power_supply is null [ 7.140072] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 7.150583] systemd[1]: Starting LSB: Set keymap... [ 7.161956] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 7.190595] systemd[1]: Starting Slices. [ 7.191095] systemd[1]: Reached target Slices. [ 7.193801] systemd[1]: Mounted Debug File System. [ 7.194475] systemd[1]: Mounted POSIX Message Queue File System. [ 7.225684] [wifi_pm]: set wl_reg_on 1 ! [ 7.255108] systemd[1]: Started Increase datagram queue length. [ 7.345048] systemd[1]: Started Restore / save the current clock. [ 7.515423] systemd[1]: Started Create list of required static device nodes for the current kernel. [ 7.605059] systemd[1]: Started Load Kernel Modules. [ 7.694928] systemd[1]: Started LSB: Set keymap. [ 7.784828] systemd[1]: Started udev Coldplug all Devices. [ 7.786874] systemd[1]: Time has been changed [ 7.787203] systemd[1]: Mounting FUSE Control File System... [ 7.950468] systemd[1]: Starting Apply Kernel Variables... [ 8.021091] systemd[1]: Mounted Configuration File System. [ 8.021436] systemd[1]: Starting Create Static Device Nodes in /dev... [ 8.070794] systemd[1]: Starting Syslog Socket. [ 8.075669] systemd[1]: Listening on Syslog Socket. [ 8.075816] systemd[1]: Starting Journal Service... [ 8.160032] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 8.215576] systemd[1]: Started Journal Service. [ 8.676423] systemd-udevd[185]: starting version 215 [ 8.901175] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 8.989988] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.000306] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.001413] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.004564] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.004997] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.005441] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.005816] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.006349] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.010515] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.010975] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.013118] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.014084] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.015756] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.016675] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.018514] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.019452] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.019889] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.020546] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.020913] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.027089] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.028109] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.028686] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.029043] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.030138] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.030586] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.030976] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.031335] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.031718] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.032107] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.032477] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.033007] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.033824] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.037947] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.038373] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.038821] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.039635] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.040268] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.040674] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.041120] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.041480] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.041843] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.042556] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.043008] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.043384] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.043770] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.044123] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.044485] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.044828] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.045151] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.045563] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.045908] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.046285] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.046707] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.047090] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.047743] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.048180] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.048661] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.049284] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.050210] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.050593] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.051033] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.051423] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.051886] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.052289] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B [ 9.160064] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 9.527659] EXT4-fs (mmcblk0p1): warning: mounting fs with errors, running e2fsck is recommended [ 9.530951] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro [ 9.747885] Adding 131068k swap on /var/swap. Priority:-1 extents:1 across:131068k SS [ 10.160055] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 10.162099] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 10.867709] systemd-journald[184]: Received request to flush runtime journal from PID 1 [ 11.160064] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 11.169413] gmac0: probed [ 11.200425] gmac0 gmac0: eth0: eth0: PHY ID 001cc915 at 0 IRQ poll (gmac0-0:00) [ 12.160061] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 12.397408] EXT4-fs warning (device mmcblk0p1): ext4_resize_begin:32: There are errors in the filesystem, so online resizing is not allowed [ 12.744485] Registered IR keymap rc-empty [ 12.746538] rc0: sunxi-ir as /devices/virtual/rc/rc0 [ 12.752638] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-ir) registered at minor = 0 [ 13.160038] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 13.161097] [mmc]: sdc1 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 14.160027] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 15.160023] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 16.160020] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 16.160051] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 16.160180] [mmc]: sdc1 power_supply is null [ 16.162761] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 16.164286] [mmc]: sdc1 power_supply is null [ 16.180046] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 16.200303] PHY: gmac0-0:00 - Link is Up - 1000/Full [ 16.201992] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 17.200020] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 18.200019] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 19.200021] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 19.202050] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 20.200018] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 21.200023] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 21.270022] eth0: no IPv6 routers present [ 22.200021] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 22.201067] [mmc]: sdc1 set ios: clk 300000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 23.200019] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 24.200017] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 25.200018] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 25.200048] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 25.200176] [mmc]: sdc1 power_supply is null [ 25.202757] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 25.204281] [mmc]: sdc1 power_supply is null [ 25.220058] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 25.242151] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 26.240021] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 27.240021] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 28.240020] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 28.242049] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 29.240021] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 30.240019] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 31.240020] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 31.241062] [mmc]: sdc1 set ios: clk 200000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 32.240019] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 33.240023] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 34.240020] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 34.240051] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 34.240178] [mmc]: sdc1 power_supply is null [ 34.242760] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 34.244284] [mmc]: sdc1 power_supply is null [ 34.260039] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 34.282328] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 35.280021] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 36.280020] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 37.280020] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 37.282049] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 38.280018] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 39.280018] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 40.280018] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 40.281056] [mmc]: sdc1 set ios: clk 150000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 41.280043] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 42.280018] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 43.280016] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 43.280042] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 43.280160] [mmc]: sdc1 power_supply is null root@orangepiplus2e:~# Link to comment Share on other sites More sharing options...
tkaiser Posted October 16, 2016 Share Posted October 16, 2016 Your installation (or SD card) is broken anyway: 'There are errors in the filesystem, so online resizing is not allowed' Please start here again: http://docs.armbian.com/User-Guide_Getting-Started/#how-to-prepare-a-sd-card 1 Link to comment Share on other sites More sharing options...
UnixOutlaw Posted November 8, 2016 Share Posted November 8, 2016 I couldn't get WiFi working on my home network Armbian Jessie on OPi+2E using wicd - so I removed wicd and installed network-manager and network-manager-xfce... and it just worked... Link to comment Share on other sites More sharing options...
txumino Posted November 24, 2016 Author Share Posted November 24, 2016 Your installation (or SD card) is broken anyway: 'There are errors in the filesystem, so online resizing is not allowed' Please start here again: http://docs.armbian.com/User-Guide_Getting-Started/#how-to-prepare-a-sd-card Hello again. I bought a new memory card, I installed Armbian_5.20_Orangepiplus2e_Debian_jessie_3.4.112_desktop again and I executed Apt-get update Apt-get upgrade reboot And still without detection wifi, I leave here dmseg root@orangepiplus2e:~# dmesg [ 0.000000] Booting Linux on physical CPU 0 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 3.4.112-sun8i (root@xenial) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.1) ) #10 SMP PREEMPT Sun Oct 23 16:06:55 CEST 2016 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: sun8i [ 0.000000] cma: CMA: reserved 256 MiB at b0000000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] On node 0 totalpages: 524288 [ 0.000000] free_area_init_node: node 0, pgdat c0a22a00, node_mem_map c0b5c000 [ 0.000000] Normal zone: 1710 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 192850 pages, LIFO batch:31 [ 0.000000] HighMem zone: 2898 pages used for memmap [ 0.000000] HighMem zone: 326830 pages, LIFO batch:31 [ 0.000000] script_init enter! [ 0.000000] script_init exit! [ 0.000000] PERCPU: Embedded 8 pages/cpu @c1d79000 s11968 r8192 d12608 u32768 [ 0.000000] pcpu-alloc: s11968 r8192 d12608 u32768 alloc=8*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 519680 [ 0.000000] Kernel command line: console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 cgroup_enable=memory swapaccount=1 panic=10 consoleblank=0 enforcing=0 loglevel=1 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] allocated 4194304 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Memory: 2048MB = 2048MB total [ 0.000000] Memory: 1796488k/1796488k available, 300664k reserved, 1056768K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) [ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc095ad38 (9548 kB) [ 0.000000] .init : 0xc095b000 - 0xc09adec0 ( 332 kB) [ 0.000000] .data : 0xc09ae000 - 0xc0a27850 ( 487 kB) [ 0.000000] .bss : 0xc0a28004 - 0xc0b5b090 (1229 kB) [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] Additional per-CPU info printed with stalls. [ 0.000000] NR_IRQS:544 [ 0.000000] Architected local timer running at 24.00MHz. [ 0.000000] Switching to timer-based delay loop [ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms [ 0.000000] Console: colour dummy device 80x30 [ 0.000000] console [tty1] enabled [ 0.000270] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000) [ 0.000293] pid_max: default: 32768 minimum: 301 [ 0.000631] Mount-cache hash table entries: 512 [ 0.001594] Initializing cgroup subsys cpuacct [ 0.001610] Initializing cgroup subsys memory [ 0.001656] Initializing cgroup subsys devices [ 0.001668] Initializing cgroup subsys freezer [ 0.001679] Initializing cgroup subsys blkio [ 0.001703] Initializing cgroup subsys perf_event [ 0.001782] CPU: Testing write buffer coherency: ok [ 0.001827] ftrace: allocating 25741 entries in 76 pages [ 0.030293] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.030310] [sunxi_smp_prepare_cpus] enter [ 0.030346] Setting up static identity map for 0x40691778 - 0x406917d0 [ 0.031300] CPU1: Booted secondary processor [ 0.031300] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.031431] CPU2: Booted secondary processor [ 0.031431] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002 [ 0.040489] CPU3: Booted secondary processor [ 0.040489] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003 [ 0.040609] Brought up 4 CPUs [ 0.040609] SMP: Total of 4 processors activated (19200.00 BogoMIPS). [ 0.040900] devtmpfs: initialized [ 0.050590] wakeup src cnt is : 2. [ 0.050604] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000 [ 0.050615] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x0 [ 0.050626] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40 [ 0.050637] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000 [ 0.050647] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x8 [ 0.050658] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40 [ 0.050669] sunxi pm init [ 0.050806] pinctrl core: initialized pinctrl subsystem [ 0.060838] NET: Registered protocol family 16 [ 0.061831] DMA: preallocated 2048 KiB pool for atomic coherent allocations [ 0.061897] script_sysfs_init success [ 0.061926] sunxi_dump_init success [ 0.062806] gpiochip_add: registered GPIOs 0 to 383 on device: sunxi-pinctrl [ 0.062806] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver [ 0.062806] plat: add bmp085 device [ 0.062806] plat: add pcf8591 device [ 0.062806] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.062806] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.062806] script config pll_video to 297 Mhz [ 0.062806] script config pll_de to 864 Mhz [ 0.062806] script config pll_ve to 402 Mhz [ 0.062806] sunxi_default_clk_init [ 0.062806] try to set pll6ahb1 to 200000000 [ 0.062806] try to set ahb clk source to pll6ahb1 [ 0.062806] set ahb clk source to pll6ahb1 [ 0.062806] try to set ahb1 to 200000000 [ 0.062806] try to set apb1 to 100000000 [ 0.070234] bio: create slab <bio-0> at 0 [ 0.070305] [ARISC] :sunxi-arisc driver v1.04 [ 0.090492] [ARISC] :arisc version: [v0.1.58] [ 0.181041] [ARISC] :sunxi-arisc driver v1.04 startup succeeded [ 0.182638] SCSI subsystem initialized [ 0.182638] usbcore: registered new interface driver usbfs [ 0.182638] usbcore: registered new interface driver hub [ 0.182638] usbcore: registered new device driver usb [ 0.182638] twi_chan_cfg()340 - [twi0] has no twi_regulator. [ 0.182638] twi_chan_cfg()340 - [twi1] has no twi_regulator. [ 0.182638] twi_chan_cfg()340 - [twi2] has no twi_regulator. [ 0.182638] Linux video capture interface: v2.00 [ 0.182638] Advanced Linux Sound Architecture Driver Version 1.0.25. [ 0.182638] cfg80211: Calling CRDA to update world regulatory domain [ 0.182638] Switching to clocksource arch_sys_counter [ 0.193989] FS-Cache: Loaded [ 0.194276] CacheFiles: Loaded [ 0.205462] NET: Registered protocol family 2 [ 0.216690] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.217291] TCP established hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.219050] TCP bind hash table entries: 65536 (order: 7, 786432 bytes) [ 0.220140] TCP: Hash tables configured (established 131072 bind 65536) [ 0.220152] TCP: reno registered [ 0.220166] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.220205] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.220563] NET: Registered protocol family 1 [ 0.220978] RPC: Registered named UNIX socket transport module. [ 0.220990] RPC: Registered udp transport module. [ 0.220998] RPC: Registered tcp transport module. [ 0.221006] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.221197] Trying to unpack rootfs image as initramfs... [ 0.408542] Freeing initrd memory: 3060K [ 0.408924] hw perfevents: enabled with ARMv7 Cortex_A7 PMU driver, 5 counters available [ 0.409051] sunxi_reg_init enter [ 0.409973] audit: initializing netlink socket (disabled) [ 0.410072] type=2000 audit(0.410:1): initialized [ 0.411296] highmem bounce pool size: 64 pages [ 0.412175] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.412358] misc fatfs initialized [ 0.413080] NFS: Registering the id_resolver key type [ 0.413463] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.413477] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 0.414239] NTFS driver 2.1.30 [Flags: R/W]. [ 0.414567] fuse init (API version 7.18) [ 0.415280] Btrfs loaded [ 0.415304] msgmni has been set to 1450 [ 0.416710] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) [ 0.416731] io scheduler noop registered [ 0.416740] io scheduler deadline registered [ 0.416807] io scheduler cfq registered (default) [ 0.417220] [DISP]disp_module_init [ 0.417520] cmdline,init_disp= [ 0.417548] cmdline,disp= [ 0.427251] [DISP] Fb_map_kernel_logo,line:932:Fb_map_kernel_logo failed! [ 0.443725] Console: switching to colour frame buffer device 160x45 [ 0.461083] [DISP]disp_module_init finish [ 0.461306] sw_uart_get_devinfo()1503 - uart0 has no uart_regulator. [ 0.461624] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI [ 0.461638] sw_uart_pm()890 - uart0 clk is already enable [ 0.461656] sw_console_setup()1233 - console setup baud 115200 parity n bits 8, flow n [ 0.461990] console [ttyS0] enabled [ 0.462528] sunxi_cmatest_init enter [ 0.462573] sunxi_cmatest_init success [ 0.466669] brd: module loaded [ 0.470658] loop: module loaded [ 0.470957] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator. [ 0.470972] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator. [ 0.471571] spi spi0: master is unqueued, this is deprecated [ 0.471881] tun: Universal TUN/TAP device driver, 1.6 [ 0.471891] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com> [ 0.473185] PPP generic driver version 2.4.2 [ 0.473395] PPP BSD Compression module registered [ 0.473405] PPP Deflate Compression module registered [ 0.476158] PPP MPPE Compression module registered [ 0.476177] NET: Registered protocol family 24 [ 0.476252] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.496354] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.496387] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1 [ 0.496995] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000 [ 0.510036] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00 [ 0.510649] hub 1-0:1.0: USB hub found [ 0.510674] hub 1-0:1.0: 1 port detected [ 0.531048] sunxi-ehci sunxi-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.531078] sunxi-ehci sunxi-ehci.2: new USB bus registered, assigned bus number 2 [ 0.531497] sunxi-ehci sunxi-ehci.2: irq 106, io mem 0xf1c1b000 [ 0.550033] sunxi-ehci sunxi-ehci.2: USB 0.0 started, EHCI 1.00 [ 0.550050] ehci_irq: highspeed device connect [ 0.550559] hub 2-0:1.0: USB hub found [ 0.550586] hub 2-0:1.0: 1 port detected [ 0.570949] sunxi-ehci sunxi-ehci.3: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.570978] sunxi-ehci sunxi-ehci.3: new USB bus registered, assigned bus number 3 [ 0.571370] sunxi-ehci sunxi-ehci.3: irq 108, io mem 0xf1c1c000 [ 0.590031] sunxi-ehci sunxi-ehci.3: USB 0.0 started, EHCI 1.00 [ 0.590574] hub 3-0:1.0: USB hub found [ 0.590594] hub 3-0:1.0: 1 port detected [ 0.610952] sunxi-ehci sunxi-ehci.4: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.610981] sunxi-ehci sunxi-ehci.4: new USB bus registered, assigned bus number 4 [ 0.611373] sunxi-ehci sunxi-ehci.4: irq 110, io mem 0xf1c1d000 [ 0.630043] sunxi-ehci sunxi-ehci.4: USB 0.0 started, EHCI 1.00 [ 0.630578] hub 4-0:1.0: USB hub found [ 0.630602] hub 4-0:1.0: 1 port detected [ 0.630986] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 0.651063] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 0.651092] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 5 [ 0.651124] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400 [ 0.714559] hub 5-0:1.0: USB hub found [ 0.714581] hub 5-0:1.0: 1 port detected [ 0.734948] sunxi-ohci sunxi-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 0.734977] sunxi-ohci sunxi-ohci.2: new USB bus registered, assigned bus number 6 [ 0.735008] sunxi-ohci sunxi-ohci.2: irq 107, io mem 0xf1c1b400 [ 0.794580] hub 6-0:1.0: USB hub found [ 0.794605] hub 6-0:1.0: 1 port detected [ 0.810044] ehci_irq: highspeed device disconnect [ 0.810072] ohci_irq: fullspeed or lowspeed device connect [ 0.814980] sunxi-ohci sunxi-ohci.3: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 0.815008] sunxi-ohci sunxi-ohci.3: new USB bus registered, assigned bus number 7 [ 0.815041] sunxi-ohci sunxi-ohci.3: irq 109, io mem 0xf1c1c400 [ 0.874573] hub 7-0:1.0: USB hub found [ 0.874593] hub 7-0:1.0: 1 port detected [ 0.894963] sunxi-ohci sunxi-ohci.4: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 0.894990] sunxi-ohci sunxi-ohci.4: new USB bus registered, assigned bus number 8 [ 0.895021] sunxi-ohci sunxi-ohci.4: irq 111, io mem 0xf1c1d400 [ 0.954541] hub 8-0:1.0: USB hub found [ 0.954561] hub 8-0:1.0: 1 port detected [ 0.954901] Initializing USB Mass Storage driver... [ 0.955131] usbcore: registered new interface driver usb-storage [ 0.955142] USB Mass Storage support registered. [ 0.955198] usbcore: registered new interface driver ums-alauda [ 0.955246] usbcore: registered new interface driver ums-cypress [ 0.955302] usbcore: registered new interface driver ums-datafab [ 0.955355] usbcore: registered new interface driver ums_eneub6250 [ 0.955403] usbcore: registered new interface driver ums-freecom [ 0.955450] usbcore: registered new interface driver ums-isd200 [ 0.955496] usbcore: registered new interface driver ums-jumpshot [ 0.955543] usbcore: registered new interface driver ums-karma [ 0.955592] usbcore: registered new interface driver ums-onetouch [ 0.955655] usbcore: registered new interface driver ums-realtek [ 0.955706] usbcore: registered new interface driver ums-sddr09 [ 0.955754] usbcore: registered new interface driver ums-sddr55 [ 0.955803] usbcore: registered new interface driver ums-usbat [ 0.956019] uinput result 0 , vmouse_init [ 0.956627] mousedev: PS/2 mouse device common for all mice [ 0.956853] sunxikbd_init failed. [ 0.957598] ls_fetch_sysconfig_para: type err device_used = -1073060220. [ 0.957609] =========script_get_err============ [ 0.957617] ltr_init: ls_fetch_sysconfig_para err. [ 0.957930] [RTC] WARNING: Rtc time will be wrong!! [ 0.957940] [RTC] WARNING: use *internal OSC* as clock source [ 0.958190] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0 [ 0.958239] i2c /dev entries driver [ 0.958638] IR RC5(x) protocol handler initialized [ 0.958765] sunxi cedar version 0.1 [ 0.958811] [cedar]: install start!!! [ 0.959005] [cedar]: install end!!! [ 0.959245] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x18) [ 0.959417] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x19) [ 0.959586] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x1a) [ 0.959754] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x29) [ 0.959922] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2a) [ 0.960094] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2b) [ 0.960264] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4c) [ 0.960434] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4d) [ 0.960602] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4e) [ 0.960802] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x18) [ 0.960997] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x19) [ 0.961192] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1a) [ 0.961387] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x29) [ 0.961582] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2a) [ 0.961777] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2b) [ 0.961972] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4c) [ 0.962167] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4d) [ 0.962362] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4e) [ 0.962377] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0 [ 0.962540] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbf [ 0.962717] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0) [ 0.962730] wdt_enable, write reg 0xf1c20cb8 val 0x00000000 [ 0.962741] timeout_to_interv, line 167 [ 0.962749] interv_to_timeout, line 189 [ 0.962758] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec [ 0.963168] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com [ 0.963382] calibrat: max_cpufreq 1296Mhz Type 0! [ 0.963691] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.111 2015-4-13 15:24) Compiled in Oct 23 2016 at 16:04:43 [ 0.963724] [mmc]: get mmc0's sdc_power is null! [ 0.963752] [mmc]: get mmc1's sdc_power is null! [ 0.963761] [mmc]: get mmc1's 2xmode ok, val = 1 [ 0.963770] [mmc]: get mmc1's ddrmode ok, val = 1 [ 0.963798] [mmc]: get mmc2's sdc_power is null! [ 0.963807] [mmc]: get mmc2's 2xmode ok, val = 1 [ 0.963817] [mmc]: get mmc2's ddrmode ok, val = 1 [ 0.963830] [mmc]: MMC host used card: 0x7, boot card: 0x0, io_card 2 [ 0.967455] [mmc]: sdc0 power_supply is null [ 0.970988] no blue_led, ignore it! [ 0.971232] Registered led device: red_led [ 0.971349] Registered led device: green_led [ 0.971366] no led_0, ignore it! [ 0.971374] no led_1, ignore it! [ 0.971381] no led_2, ignore it! [ 0.971388] no led_3, ignore it! [ 0.971395] no led_4, ignore it! [ 0.971402] no led_5, ignore it! [ 0.971409] no led_6, ignore it! [ 0.971416] no led_7, ignore it! [ 0.972240] usbcore: registered new interface driver usbhid [ 0.972253] usbhid: USB HID core driver [ 0.977073] asoc: sndcodec <-> sunxi-codec mapping ok [ 0.977937] [DAUDIO]sunxi-daudio cannot find any using configuration for controllers, return directly! [ 0.978124] [I2S]snddaudio cannot find any using configuration for controllers, return directly! [ 0.978137] [DAUDIO0] driver not init,just return. [ 0.981905] asoc: sndhdmi <-> sunxi-hdmiaudio.0 mapping ok [ 0.982951] oprofile: using arm/armv7-ca7 [ 0.983140] u32 classifier [ 0.983149] Performance counters on [ 0.983156] input device check on [ 0.983163] Actions configured [ 0.983353] IPv4 over IPv4 tunneling driver [ 0.983983] TCP: bic registered [ 0.983995] TCP: cubic registered [ 0.984002] TCP: westwood registered [ 0.984010] TCP: highspeed registered [ 0.984017] TCP: hybla registered [ 0.984024] TCP: htcp registered [ 0.984032] TCP: vegas registered [ 0.984039] TCP: veno registered [ 0.984046] TCP: scalable registered [ 0.984054] TCP: lp registered [ 0.984061] TCP: yeah registered [ 0.984068] TCP: illinois registered [ 0.984076] Initializing XFRM netlink socket [ 0.984315] NET: Registered protocol family 10 [ 0.985475] NET: Registered protocol family 17 [ 0.985506] NET: Registered protocol family 15 [ 0.985556] Registering the dns_resolver key type [ 0.985894] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 [ 0.985915] ThumbEE CPU extension supported. [ 0.985938] Registering SWP/SWPB emulation handler [ 0.986491] registered taskstats version 1 [ 0.986942] cmdline,disp= [ 0.987247] [HDMI] power vcc-hdmi-18 [ 1.017969] ths_fetch_sysconfig_para: type err device_used = 1. [ 1.019239] CPU Budget:corekeeper enabled [ 1.019470] CPU Budget:Register notifier [ 1.019482] CPU Budget:register Success [ 1.019496] sunxi-budget-cooling sunxi-budget-cooling: Cooling device registered: thermal-budget-0 [ 1.022739] [rf_pm]: module power0 name vcc-wifi-33 [ 1.022754] [rf_pm]: failed to fetch module_power0_vol [ 1.022764] [rf_pm]: mod has no chip_en gpio [ 1.022772] [rf_pm]: regulator on. [ 1.022787] [rf_pm]: set losc_out 32k out[wifi_pm]: set wl_reg_on 1 ! [ 1.052718] mmc0: new high speed SDHC card at address 19b3 [ 1.053213] mmcblk0: mmc0:19b3 SE08G 7.28 GiB [ 1.054468] mmcblk0: p1 [ 1.055024] mmcblk mmc0:19b3: Card claimed for testing. [ 1.055038] mmc0:19b3: SE08G 7.28 GiB [ 1.056616] [mmc]: sdc2 power_supply is null [ 1.123197] hci: ERR: sunxi_ehci is already enable, can not enable again [ 1.123210] hci: ERR: sunxi_ohci is already enable, can not enable again [ 1.134461] mmc2: new high speed DDR MMC card at address 0001 [ 1.134932] mmcblk1: mmc2:0001 AWPD3R 14.5 GiB [ 1.135164] mmcblk1boot0: mmc2:0001 AWPD3R partition 1 4.00 MiB [ 1.135398] mmcblk1boot1: mmc2:0001 AWPD3R partition 2 4.00 MiB [ 1.136513] mmcblk1: p1 [ 1.138126] mmcblk1boot1: unknown partition table [ 1.139489] mmcblk1boot0: unknown partition table [ 1.139706] mmcblk mmc2:0001: Card claimed for testing. [ 1.139719] mmc2:0001: AWPD3R 14.5 GiB [ 1.141279] [mmc]: sdc1 power_supply is null [ 1.170046] usb 6-1: new full-speed USB device number 2 using sunxi-ohci [ 1.195173] [mmc]: sdc1 power_supply is null [ 1.199284] [mmc]: sdc1 power_supply is null [ 1.223234] [wifi_pm]: wifi gpio init is OK !! [ 1.223302] [rfkill]: init no bt used in configuration [ 1.223312] ALSA device list: [ 1.223319] #0: audiocodec [ 1.223326] #1: sndhdmi [ 1.224113] Freeing init memory: 328K [ 1.258860] [mmc]: sdc1 power_supply is null [ 1.262688] [mmc]: sdc1 power_supply is null [ 1.269353] systemd-udevd[100]: starting version 215 [ 1.326050] [mmc]: sdc1 power_supply is null [ 1.330113] [mmc]: sdc1 power_supply is null [ 1.402758] [mmc]: sdc1 power_supply is null [ 1.463705] logitech-djreceiver 0003:046D:C52B.0003: hiddev0,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-sunxi-ohci-1/input2 [ 1.471042] logitech-djdevice 0003:046D:C52B.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech Unifying Device. Wireless PID:4024] on usb-sunxi-ohci-1:1 [ 1.620044] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device0, type=4, mode=5 [ 2.593543] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) [ 3.840314] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR) [ 3.840645] systemd[1]: Detected architecture 'arm'. [ 3.851071] systemd[1]: Set hostname to <orangepiplus2e>. [ 4.149527] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory. [ 4.152403] systemd[1]: Expecting device dev-ttyS0.device... [ 4.153120] systemd[1]: Starting Forward Password Requests to Wall Directory Watch. [ 4.153345] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 4.153418] systemd[1]: Starting Remote File Systems (Pre). [ 4.153817] systemd[1]: Reached target Remote File Systems (Pre). [ 4.153982] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point. [ 4.154912] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 4.155020] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch. [ 4.155220] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 4.155281] systemd[1]: Starting Paths. [ 4.155604] systemd[1]: Reached target Paths. [ 4.155666] systemd[1]: Starting Encrypted Volumes. [ 4.156000] systemd[1]: Reached target Encrypted Volumes. [ 4.156071] systemd[1]: Starting Root Slice. [ 4.156480] systemd[1]: Created slice Root Slice. [ 4.156540] systemd[1]: Starting User and Session Slice. [ 4.157028] systemd[1]: Created slice User and Session Slice. [ 4.157094] systemd[1]: Starting /dev/initctl Compatibility Named Pipe. [ 4.157638] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [ 4.157701] systemd[1]: Starting Delayed Shutdown Socket. [ 4.158157] systemd[1]: Listening on Delayed Shutdown Socket. [ 4.158219] systemd[1]: Starting Journal Socket (/dev/log). [ 4.158679] systemd[1]: Listening on Journal Socket (/dev/log). [ 4.158761] systemd[1]: Starting udev Control Socket. [ 4.159160] systemd[1]: Listening on udev Control Socket. [ 4.159234] systemd[1]: Starting udev Kernel Socket. [ 4.159649] systemd[1]: Listening on udev Kernel Socket. [ 4.159736] systemd[1]: Starting Journal Socket. [ 4.160247] systemd[1]: Listening on Journal Socket. [ 4.160380] systemd[1]: Starting System Slice. [ 4.160866] systemd[1]: Created slice System Slice. [ 4.160963] systemd[1]: Started File System Check on Root Device. [ 4.161018] systemd[1]: Starting system-serial\x2dgetty.slice. [ 4.161600] systemd[1]: Created slice system-serial\x2dgetty.slice. [ 4.161663] systemd[1]: Starting system-getty.slice. [ 4.162178] systemd[1]: Created slice system-getty.slice. [ 4.162310] systemd[1]: Starting Increase datagram queue length... [ 4.200818] systemd[1]: Starting Restore / save the current clock... [ 4.250845] systemd[1]: Starting udev Coldplug all Devices... [ 4.324531] systemd[1]: Starting Load Kernel Modules... [ 4.381231] systemd[1]: Mounting Debug File System... [ 4.491011] [mmc]: sdc1 power_supply is null [ 4.491050] systemd[1]: Starting Create list of required static device nodes for the current kernel... [ 4.545180] [mmc]: sdc1 power_supply is null [ 4.549292] [mmc]: sdc1 power_supply is null [ 4.550898] systemd[1]: Mounting POSIX Message Queue File System... [ 4.589425] [wifi_pm]: set wl_reg_on 1 ! [ 4.597115] UMP: UMP device driver loaded [ 4.608858] [mmc]: sdc1 power_supply is null [ 4.610814] systemd[1]: Mounted Huge Pages File System. [ 4.612697] mali clk: 252 MHz [ 4.612741] [mmc]: sdc1 power_supply is null [ 4.612919] mali clk: 252 MHz [ 4.616570] systemd[1]: Started Set Up Additional Binary Formats. [ 4.616701] systemd[1]: Starting LSB: Set keymap... [ 4.622712] Mali: Mali device driver loaded [ 4.675219] [mmc]: sdc1 power_supply is null [ 4.679328] [mmc]: sdc1 power_supply is null [ 4.680614] systemd[1]: Starting Slices. [ 4.681139] systemd[1]: Reached target Slices. [ 4.683882] systemd[1]: Mounted POSIX Message Queue File System. [ 4.684480] systemd[1]: Mounted Debug File System. [ 4.720578] systemd[1]: Started Increase datagram queue length. [ 4.752053] [mmc]: sdc1 power_supply is null [ 4.804990] systemd[1]: Started Restore / save the current clock. [ 4.985334] systemd[1]: Started Load Kernel Modules. [ 5.055198] systemd[1]: Started Create list of required static device nodes for the current kernel. [ 5.104991] systemd[1]: Started LSB: Set keymap. [ 5.154881] systemd[1]: Started udev Coldplug all Devices. [ 5.156953] systemd[1]: Time has been changed [ 5.157526] systemd[1]: Starting Create Static Device Nodes in /dev... [ 5.241031] systemd[1]: Mounted Configuration File System. [ 5.241225] systemd[1]: Mounting FUSE Control File System... [ 5.330570] systemd[1]: Starting Apply Kernel Variables... [ 5.410798] systemd[1]: Starting Syslog Socket. [ 5.415841] systemd[1]: Listening on Syslog Socket. [ 5.416008] systemd[1]: Starting Journal Service... [ 5.485527] systemd[1]: Started Journal Service. [ 5.734897] systemd-udevd[186]: starting version 215 [ 6.138894] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x77) [ 6.138931] bmp085: probe of 0-0077 failed with error -70 [ 6.164328] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x48) [ 6.164549] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x48) [ 6.599992] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro [ 6.834513] Adding 131068k swap on /var/swap. Priority:-1 extents:1 across:131068k SS [ 8.177648] systemd-journald[185]: Received request to flush runtime journal from PID 1 [ 8.517449] gmac0: probed [ 8.550404] gmac0 gmac0: eth0: eth0: PHY ID 001cc915 at 0 IRQ poll (gmac0-0:00) [ 10.318363] Registered IR keymap rc-empty [ 10.319018] rc0: sunxi-ir as /devices/virtual/rc/rc0 [ 10.320294] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-ir) registered at minor = 0 [ 10.521249] [DISP] disp_ioctl,line:1584:para err in disp_ioctl, cmd = 0x0,screen id = 65536 [ 10.580389] [drm] Initialized drm 1.1.0 20060810 [ 10.584891] Mali DRM initialize, driver name: mali_drm, version 2.1 [ 10.585442] [drm] Initialized mali_drm 2.1.1 20101111 on minor 0 [ 10.585503] Mali DRM initialize, driver name: mali_drm, version 2.1 [ 10.585912] [drm] Initialized mali_drm 2.1.1 20101111 on minor 1 [ 11.036470] vmouse_input_dev_open [ 13.550301] PHY: gmac0-0:00 - Link is Up - 1000/Full [ 18.890041] eth0: no IPv6 routers present [ 18.994893] Bluetooth: Core ver 2.16 [ 18.994966] NET: Registered protocol family 31 [ 18.994974] Bluetooth: HCI device and connection manager initialized [ 18.994985] Bluetooth: HCI socket layer initialized [ 18.994992] Bluetooth: L2CAP socket layer initialized [ 18.995012] Bluetooth: SCO socket layer initialized [ 19.014325] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 19.014340] Bluetooth: BNEP filters: protocol multicast [ 19.837680] Bluetooth: RFCOMM TTY layer initialized [ 19.837709] Bluetooth: RFCOMM socket layer initialized [ 19.837719] Bluetooth: RFCOMM ver 1.11 root@orangepiplus2e:~# Link to comment Share on other sites More sharing options...
txumino Posted February 17, 2017 Author Share Posted February 17, 2017 Update:I bought another Orange Pi Plus 2E and it works perfectly the wifi, the other one that I have and for which I opened this post is defective. 2 Link to comment Share on other sites More sharing options...
