Ting Zhou Posted March 16, 2017 Share Posted March 16, 2017 Hi All, I have attached an ASUS Xonar Essence One at usb-sunxi-ehci-1, high speed : USB Audio to OrangePi PC. when I use alsa to play sound, the system cannot attain the correct sample rate. After system is booted, the sampling rate is 192000. Now experiment starts Here is the information from /proc/asound/card2/stream0, when nothing is played. Quote ASUS ASUS Xonar Essence One at usb-sunxi-ehci-1, high speed : USB Audio Playback: Status: Stop Interface 1 Altset 1 Format: S16_LE Channels: 2 Endpoint: 6 OUT (ASYNC) Rates: 44100, 48000, 88200, 96000, 176400, 192000 Data packet interval: 125 us Interface 1 Altset 2 Format: S32_LE Channels: 2 Endpoint: 6 OUT (ASYNC) Rates: 44100, 48000, 88200, 96000, 176400, 192000 Data packet interval: 125 us Then I "play" 44100 Hz via alsa, by "cat /dev/urandom | aplay -D hw:2,0 -f S16_LE -c2 -r44100". Here is the result Quote Playback: Status: Running Interface = 1 Altset = 1 URBs = 8 [ 8 8 8 8 8 8 8 8 ] Packet Size = 104 Momentary freq = 48000 Hz (0x6.0000) Feedback Format = 14.18 Interface 1 Altset 1 Format: S16_LE Channels: 2 Endpoint: 6 OUT (ASYNC) Rates: 44100, 48000, 88200, 96000, 176400, 192000 Data packet interval: 125 us Interface 1 Altset 2 Format: S32_LE Channels: 2 Endpoint: 6 OUT (ASYNC) Rates: 44100, 48000, 88200, 96000, 176400, 192000 Data packet interval: 125 us It plays at 48000Hz. If I play at 44100 Hz again it will be correct. Quote Playback: Status: Running Interface = 1 Altset = 1 URBs = 8 [ 8 8 8 8 8 8 8 8 ] Packet Size = 104 Momentary freq = 44109 Hz (0x5.8380) Feedback Format = 16.16 Interface 1 Altset 1 Format: S16_LE Channels: 2 Endpoint: 6 OUT (ASYNC) Rates: 44100, 48000, 88200, 96000, 176400, 192000 Data packet interval: 125 us Interface 1 Altset 2 Format: S32_LE Channels: 2 Endpoint: 6 OUT (ASYNC) Rates: 44100, 48000, 88200, 96000, 176400, 192000 Data packet interval: 125 us If I let it play at 192000Hz after 44100Hz by typing "cat /dev/urandom | aplay -D hw:2,0 -f S16_LE -c2 -r192000", the sampling problem happens again Quote Playback: Status: Running Interface = 1 Altset = 1 URBs = 8 [ 8 8 8 8 8 8 8 8 ] Packet Size = 104 Momentary freq = 176438 Hz (0x16.0e00) Feedback Format = 18.14 Interface 1 Altset 1 Format: S16_LE Channels: 2 Endpoint: 6 OUT (ASYNC) Rates: 44100, 48000, 88200, 96000, 176400, 192000 Data packet interval: 125 us Interface 1 Altset 2 Format: S32_LE Channels: 2 Endpoint: 6 OUT (ASYNC) Rates: 44100, 48000, 88200, 96000, 176400, 192000 Data packet interval: 125 us There might be a solution here https://github.com/mopidy/mopidy/issues/613 But it is for raspberry Pi. I do not know how to add dwc_otg.fiq_fix_enable=1 dwc_otg.fiq_split_enable=0 to /boot/cmdline.txt. Many thanks for your help. Link to comment Share on other sites More sharing options...
zador.blood.stained Posted March 16, 2017 Share Posted March 16, 2017 14 minutes ago, Ting Zhou said: There might be a solution here https://github.com/mopidy/mopidy/issues/613 But it is for raspberry Pi. I do not know how to add dwc_otg.fiq_fix_enable=1 dwc_otg.fiq_split_enable=0 to /boot/cmdline.txt. These settings are specific to the Raspberry Pi and don't apply to other board (including Orange Pi) 15 minutes ago, Ting Zhou said: If I let it play at 192000Hz after 44100Hz by typing "cat /dev/urandom | aplay -D hw:2,0 -f S16_LE -c2 -r192000", the sampling problem happens again According to this discussion it's a kernel problem with some C-Media based sound cards (including your one). For H3 based boards only unsupported nightly images may have new enough kernel, but it also comes with some limitations. Link to comment Share on other sites More sharing options...
Ting Zhou Posted March 16, 2017 Author Share Posted March 16, 2017 Thank you for reply. At moment is there any other solutions? Link to comment Share on other sites More sharing options...
zador.blood.stained Posted March 16, 2017 Share Posted March 16, 2017 2 minutes ago, Ting Zhou said: Thank you for reply. At moment is there any other solutions? If the problem is solved with mainline kernel, then trying to find and backport the fix to the old kernel if it's possible (bisecting unfortunately won't work between legacy and mainline kernels) Using nightly or manually built images with mainline kernel if they are suitable for your use case Using another board instead of Orange Pi PC Using another sound card instead of Essence One Link to comment Share on other sites More sharing options...
Ting Zhou Posted March 16, 2017 Author Share Posted March 16, 2017 Thank you. I will wait for mainline kernel. Link to comment Share on other sites More sharing options...
