I Have an A96X with rockchip RK3228 and i tried booting armbian on it, but I got no display on HDMI.
I connected a serial adapter to it and here is the information it displays when trying to boot:
▒▒▒▒DDR Version V1.05 20160805_dbg
In
300MHz
DDR3
Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
mach:2
OUT
Boot1 Release Time: 2016-03-15, version: 2.31
ChipType = c 275
No.1 FLASH ID:2c 64 44 4b a9 0
ECC:60
SdmmcInit=0 0
BootCapSize=0
UserCapSize=76f5000
FwPartOffset=2000 , 0
StorageInit ok = 1520008
SecureMode : SBOOT_MODE_NS
hdr 0x0:ff a1 0 0 1b 0 0 0 f0 f2 2e 68 f0 f2 2e 68
hdr 0x0:a4 81 0 0 4e 23 0 0 f0 f2 2e 68 f0 f2 2e 68
hdr 0x0:ff a1 0 0 3 0 0 0 f4 f2 2e 68 f4 f2 2e 68
hdr 0x0:a4 81 0 0 44 0 0 0 f4 f2 2e 68 f4 f2 2e 68
hdr 0x0:0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Loder code check ok! theLoader 0x60000000, loadaddr: 0x2000
Loder code check ok! theLoader 0x68400000, loadaddr: 0x4000
INF TEE-CORE:init_primary_helper:319: Initializing (1.0.1-63-g23e91df-dev #16 Tu e Mar 7 10:07:15 UTC 2017 arm)
INF TEE-CORE:init_primary_helper:320: Release version: 1.8
INF TEE-CORE:init_teecore:79: teecore inits done
U-Boot 2017.02-RK322X-06-02276-ga7c7ca8-dirty (May 19 2017 - 11:16:15)
CPU: rk322x
cpu version = 3
CPU's clock information:
arm pll = 600000000HZ
periph pll = 600000000HZ
ddr pll = 600000000HZ
codec pll = 500000000HZ
Board: Rockchip platform Board
Uboot as second level loader
DRAM: Found dram banks: 1
Adding bank:0000000060000000(0000000040000000)
Reserve memory for trust os.
dram reserve bank: base = 0x68400000, size = 0x00100000
128 MiB
GIC CPU mask = 0x00000001
rk dma pl330 version: 1.4
remotectl v0.1
pwm freq=0x11e1a3
pwm_freq_nstime=0x355
SdmmcInit = 0 0
SDCard Update.
storage init OK!
Using default environment
Writing env to storage...
done
GetParam
W: Invalid Parameter's tag (0x00000000)!
Invalid parameter
No pmic detect.
SecureBootEn = 0, SecureBootLock = 0
#Boot ver: 0000-00-00#0.00
empty serial no.
normal boot.
no fuel gauge found
no fuel gauge found
read logo on state from dts [0]
no fuel gauge found
'recovery' does not seem to be a partition nor an address
Unable to boot:recovery
try to start backup
'backup' does not seem to be a partition nor an address
Unable to boot:backup
try to start rockusb
Can anybody point me to the right direction? I'd really like to turn this piece of junk into something useful 😄
Any help will be greatly appreciated!
Thank you.
