Hans
  1. Regarding x2go: I checked, if this would be an alternative. Maybe I will try it, but from what I understand means x2go Client the use of XQuartz on Mac. XQuartz gave me troubles in the past. The new MS Remote Desktop client on Mac works pretty easy, so I would prefer Xrdp.
  2. Hello, does anybody run above configuration successfully? If yes, what are the steps to make this happen? I did this: sudo apt install xorgxrdp xrdp But this is the result: xrdp (0.9.1-9+deb9u3) wird eingerichtet ... Generating 2048 bit rsa key... ssl_gen_key_xrdp1 ok saving to /etc/xrdp/rsakeys.ini Created symlink /etc/systemd/system/multi-user.target.wants/xrdp-sesman.service -> /lib/systemd/system/xrdp-sesman.service. Created symlink /etc/systemd/system/multi-user.target.wants/xrdp.service -> /lib/systemd/system/xrdp.service. A dependency job for xrdp.service failed. See 'journalctl -xe' for details. invoke-rc.d: initscript xrdp, action "start" failed. * xrdp.service - xrdp daemon Loaded: loaded (/lib/systemd/system/xrdp.service; enabled; vendor preset: enabled) Active: inactive (dead) Docs: man:xrdp(8) man:xrdp.ini(5) Okt 25 17:19:24 oc2-e1 systemd[1]: Dependency failed for xrdp daemon. Okt 25 17:19:24 oc2-e1 systemd[1]: xrdp.service: Job xrdp.service/start failed with result 'dependency'. dpkg: Fehler beim Bearbeiten des Paketes xrdp (--configure): Unterprozess installiertes post-installation-Skript gab den Fehlerwert 1 zur?ck Trigger f?r systemd (232-25+deb9u4) werden verarbeitet ... Trigger f?r man-db (2.7.6.1-2) werden verarbeitet ... xorgxrdp (0.9.1-9+deb9u3) wird eingerichtet ... Trigger f?r libc-bin (2.24-11+deb9u3) werden verarbeitet ... Fehler traten auf beim Bearbeiten von: xrdp E: Sub-process /usr/bin/dpkg returned an error code (1) Despite quite some time spent I have no glue, what 'dependency' might be missing. Appreciate any help. Hans
