Jerry Jyrer
  1. Thanks for the pointers. I added them as a local repository and upgraded with the armbian-config. Just for reference, here is what I did sudo vi /etc/apt/sources.list ## add the following line: deb [trusted=yes] file:/<mypath>/armbian/build/output/debs/ ./ cd /<mypath>/armbian/build/output/debs/ sudo bash -c 'dpkg-scanpackages . | gzip > ./Packages.gz' sudo apt update # Switch to the new kernel via armbian-config sudo armbian-config
  2. noob's here. Basically, my goal is to upgrade my system to Linux kernel 6.7 but it's not yet available via armbian-config (edge's at 6.6 at the moment). I went ahead and followed https://docs.armbian.com/Developer-Guide_Building-with-Docker/ ./compile.sh docker-shell root@6bc1d026998c:/armbian# ./compile.sh standard option : no change the kernel config, (my board) nanopim4, edge, jammy, Image with console interface (server), standard image with console interface I got the output below. How do I properly install it without flashing the whole thing -- similar to in the end what I got from armbian-config - System - Other ? My current system: $ uname -a Linux nanopim4 6.1.63-current-rockchip64 #1 SMP PREEMPT Mon Nov 20 10:52:19 UTC 2023 aarch64 aarch64 aarch64 GNU/Linux $ cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=nanopim4 BOARD_NAME="NanoPi M4" BOARDFAMILY=rockchip64 BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=014eb55b5 LINUXFAMILY=rockchip64 ARCH=arm64 IMAGE_TYPE=stable BOARD_TYPE=csc INITRD_ARCH=arm64 KERNEL_IMAGE_TYPE=Image FORCE_BOOTSCRIPT_UPDATE= VENDOR="Armbian" VENDORDOCS="https://docs.armbian.com" VENDORURL="https://www.armbian.com/" VENDORSUPPORT="https://forum.armbian.com" VENDORBUGS="https://www.armbian.com/bugs" BOOTSCRIPT_FORCE_UPDATE="no" BOOTSCRIPT_DST="boot.cmd" VERSION=23.11.1 REVISION=23.11.1 BRANCH=current $ ls -R .: debs images logs packages-hashed ./debs: armbian-bsp-cli-nanopim4-edge_24.5.0-trunk_arm64__1-PC3155-V6b08-He03b-Ba537-Rf32b.deb armbian-config_24.5.0-trunk_all__1-SAfb17-B0293-R448a.deb armbian-firmware_24.5.0-trunk_all__1-SA6b6f-B90f5-R448a.deb armbian-plymouth-theme_24.5.0-trunk_all__1-Bfcdb-R448a.deb armbian-zsh_24.5.0-trunk_all__1-SAbfee-Baafd-R448a.deb fake-ubuntu-advantage-tools_24.5.0-trunk_all__1-Bfcde-R448a.deb jammy linux-dtb-edge-rockchip64_24.5.0-trunk_arm64__6.7.6-Sb631-D6b4a-Pd972-C9e08Hfe66-HK01ba-Vc222-B067e-R448a.deb linux-headers-edge-rockchip64_24.5.0-trunk_arm64__6.7.6-Sb631-D6b4a-Pd972-C9e08Hfe66-HK01ba-Vc222-B067e-R448a.deb linux-image-edge-rockchip64_24.5.0-trunk_arm64__6.7.6-Sb631-D6b4a-Pd972-C9e08Hfe66-HK01ba-Vc222-B067e-R448a.deb linux-u-boot-nanopim4-edge_24.5.0-trunk_arm64__2022.04-Se4b6-P9ac8-H8c72-V00d9-B11a8-R448a.deb ./debs/jammy: base-files_24.5.0-trunk-12ubuntu4.6-jammy_arm64__1-jammy-1armbian1-Ba4f9-U12ubuntu4.6-R55fa.deb ./images: ./logs: archive log-docker-shell-2ff7b3cb-0116-4bab-af1f-513f2d12827b.log.ans summary-docker-shell-2ff7b3cb-0116-4bab-af1f-513f2d12827b.md ./logs/archive: log-build-12e521e3-4ee1-4e96-bd23-f7eab8343488.log.ans.zst log-docker-9dabbb7b-14fc-4f43-af22-a35f4d67be8b.log.ans.zst summary-docker-9dabbb7b-14fc-4f43-af22-a35f4d67be8b.md.zst log-build-12e521e3-4ee1-4e96-bd23-f7eab8343488.log.zst log-docker-shell-6c473265-ba31-45ab-83fb-3eafd8b54f89.log.ans.zst summary-docker-shell-6c473265-ba31-45ab-83fb-3eafd8b54f89.md.zst log-build-880a1d96-4ee1-4c1b-9fd5-ab60196a2a91.log.ans.zst summary-build-12e521e3-4ee1-4e96-bd23-f7eab8343488.md.zst log-build-880a1d96-4ee1-4c1b-9fd5-ab60196a2a91.log.zst summary-build-880a1d96-4ee1-4c1b-9fd5-ab60196a2a91.md.zst ./packages-hashed: armbian-bsp-cli-nanopim4-edge_1-PC3155-V6b08-He03b-Ba537-Rf32b_arm64.tar global jammy ./packages-hashed/global: ./packages-hashed/jammy:
  3. FWIW, with my NanopiM4 RK3399 on 6.1.50-current-rockchip6, I have usb drives disconnected when doing file transfer between them. Revert back to 5.15.93-rockchip64, it works fine. > [ +39.294664] xhci-hcd xhci-hcd.3.auto: xHCI host not responding to stop endpoint command > [ +0.013618] xhci-hcd xhci-hcd.3.auto: xHCI host controller not responding, assume dead > [ +0.000049] xhci-hcd xhci-hcd.3.auto: HC died; cleaning up > [ +0.000233] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x03 driverbyte=DRIVER_OK cmd_age=35s > [ +0.000011] usb 3-1: USB disconnect, device number 2 > [ +0.000013] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x88 88 00 00 00 00 05 2d 19 ca e0 00 00 01 00 00 00 > [ +0.000011] I/O error, dev sda, sector 22231501536 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 2 > [ +0.000188] usb 4-1: USB disconnect, device number 2 > [ +0.000014] usb 4-1.1: USB disconnect, device number 3
