TheOWL
  1. I run "armbianmonitor -u" and I got this : https://paste.armbian.com/bapohonaja My SBC is orangepi zero 2, and I tried to use it as a NAS. But sometime the system hangup because I push to much file in my usb-disk. And I G**gle about it. Somebody said because usb driver is "UAS". So I use command "lsusb -t" and bingo, my usb driver is "uas": ``` >: lsusb Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 002: ID 152d:0562 JMicron Technology Corp. / JMicron USA Technology Corp. JMS567 SATA 6Gb/s bridge Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub >: lsusb -t /: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ohci/1p, 12M /: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ohci/1p, 12M /: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ohci/1p, 12M /: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ehci/1p, 480M /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ehci/1p, 480M /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ehci/1p, 480M |__ Port 1: Dev 2, If 0, Class=Mass Storage, Driver=uas, 480M ``` I tried "/etc/modprobe.d/disable_uas.conf" with "options usb-storage quirks=152d:0562:u" and "update-alternatives -u" and reboot but failed. I tried "/boot/armbianEnv.txt" with "usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u,0x152d:0x0562:u" and "update-alternatives -u" and reboot but failed. Still "uas" there! Is that posible to change "uas" driver to "usb-storage"?
