Dear Igor,
first of all: Thank you very much for the work on armbian!
My problem now is:
I installed armbian on my cubieboard 2 (on 16 GB SD card) and first everthing went fine. I did all the management via putty and ssh but since a couple of days I can't ssh anymore. That means, ssh login with username and password is succesful, but I do not get any command line.
Besides I get a couple of other problems: One is, when I boot up, I takes about 10 min, since problems with "LSB", this means:
It takes about 5 minutes withe the message: "a start job is running for LSB: raise network interfaces"
Similiar problems occur during shutting down the system (here with a different service) ...
After login as user (non-root and root is the same), console output is stuck with:
cat: /var/run/machine.id: no such file or directory
Do yo have an idea what is causing the problme and how i can fix this?
Thank you very much in advance!
Oliver
