26 -
FYI, I'm using `Armbian_23.8.1_Nanopi-r4s_jammy_current_6.1.50` (2023-08-31) back then.
Hi, I observed the same issue on my nanopi r4s. It's just weird, and yes, sometimes you need to remove the adapter and wait several seconds before it can boot up. And sometimes, if you do this several times, the board cannot boot up. Use out-of-tree kernel provided by https://wiki.friendlyelec.com/wiki/index.php/NanoPi_R4S#Flash_to_TF can fix this, but suffer from security fixes (the distro and kernel are frozen).
Mighe related:
nanopi-r4s, enp1s0 ethernet device not found after reboot
Junkman replied to Junkman's topic in NanoPi R4S
Hi, @Igor. Thanks for your reply. Totally understand the tradeoffs between maintaining a mainline kernel and custom patches to the specified boards. I wonder how could I manually apply the PCIe driver patch to the current kernel. Do I have to rebuild the whole kernel? -
FYI, I burned the `rk3399-sd-ubuntu-focal-desktop-4.19-arm64-20230915.img.gz` to my SD card. https://wiki.friendlyelec.com/wiki/index.php/NanoPi_R4S#Flash_to_TF All the ethernet ports can be found and working (tested). So I think this might be some bugs in the Armbian build. $ cat /etc/os-release NAME="Ubuntu" VERSION="20.04.6 LTS (Focal Fossa)" ID=ubuntu ID_LIKE=debian PRETTY_NAME="Ubuntu 20.04.6 LTS" VERSION_ID="20.04" HOME_URL="https://www.ubuntu.com/" SUPPORT_URL="https://help.ubuntu.com/" BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/" PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy" VERSION_CODENAME=focal UBUNTU_CODENAME=focal $ uname -a Linux NanoPi-R4S 4.19.193 #4 SMP PREEMPT Tue Sep 5 13:32:27 CST 2023 aarch64 aarch64 aarch64 GNU/Linux pi@NanoPi-R4S:~$ ip a 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000 link/ether 68:27:19:ad:02:09 brd ff:ff:ff:ff:ff:ff inet 192.168.100.180/24 brd 192.168.100.255 scope global dynamic noprefixroute eth0 valid_lft 85478sec preferred_lft 85478sec inet6 fe80::ca10:91c8:345b:dcc4/64 scope link noprefixroute valid_lft forever preferred_lft forever 3: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000 link/ether 66:a8:c1:46:84:83 brd ff:ff:ff:ff:ff:ff inet 192.168.100.181/24 brd 192.168.100.255 scope global dynamic noprefixroute eth1 valid_lft 85926sec preferred_lft 85926sec inet6 fe80::73e6:a4c0:efc2:da25/64 scope link noprefixroute valid_lft forever preferred_lft forever $ curl -IL --interface eth0 https://1.1.1.1/dns-query HTTP/2 415 server: cloudflare date: Fri, 24 Nov 2023 13:18:11 GMT access-control-allow-origin: * cf-ray: 82b1efb8a8d47d7c-LAX $ curl -IL --interface eth1 https://1.1.1.1/dns-query HTTP/2 415 server: cloudflare date: Fri, 24 Nov 2023 13:18:15 GMT access-control-allow-origin: * cf-ray: 82b1efd0c9a67eb7-LAX -
Hi, all. After I upgraded the system and rebooted, the secondary ethernet port(i.e. the LAN port) is gone. The system info: https://paste.armbian.com/ekotoqigos nanopi-r4s:~:% ip a 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000 link/ether 68:27:19:ad:02:09 brd ff:ff:ff:ff:ff:ff inet 192.168.100.180/24 brd 192.168.100.255 scope global dynamic noprefixroute eth0 valid_lft 85963sec preferred_lft 85963sec inet6 fe80::ca55:3549:7a23:57fa/64 scope link noprefixroute valid_lft forever preferred_lft forever nanopi-r4s:~:% sudo dmesg | grep -i pcie [ 2.211030] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges: [ 2.211102] rockchip-pcie f8000000.pcie: MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000 [ 2.211138] rockchip-pcie f8000000.pcie: IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000 [ 2.212106] rockchip-pcie f8000000.pcie: no bus scan delay, default to 0 ms [ 2.212182] rockchip-pcie f8000000.pcie: no vpcie12v regulator found [ 2.713110] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout! [ 2.713187] rockchip-pcie: probe of f8000000.pcie failed with error -110 nanopi-r4s:~:% uname -a Linux nanopi-r4s 6.1.50-current-rockchip64 #3 SMP PREEMPT Wed Aug 30 14:11:13 UTC 2023 aarch64 aarch64 aarch64 GNU/Linux nanopi-r4s:~:% cat /etc/os-release PRETTY_NAME="Armbian 23.8.1 jammy" NAME="Ubuntu" VERSION_ID="22.04" VERSION="22.04.3 LTS (Jammy Jellyfish)" VERSION_CODENAME=jammy ID=ubuntu ID_LIKE=debian HOME_URL="https://www.armbian.com" SUPPORT_URL="https://forum.armbian.com" BUG_REPORT_URL="https://www.armbian.com/bugs" PRIVACY_POLICY_URL="https://www.armbian.com" UBUNTU_CODENAME=jammy ARMBIAN_PRETTY_NAME="Armbian 23.8.1 jammy" I've checked the following post, and this bug should already be fixed, I don't know why it reappeared. The kernel message is old message: `PCIe link training gen1 timeout!`. I expect the new message should be something like: `PCIe link training gen1 timeout with x%d!\n`. It seems that the `drivers/pci/controller/pcie-rockchip-host.c` patch is not included in the latest nanopi r4s jammy 6.1 kernel? https://github.com/armbian/build/pull/4308/files NanoPi R4s, enp1s0 ethernet device not showed up after reboot
Hi, @Werner. I installed the packages, does the following output means I enabled Panfrost GPU driver successfully? But the GPU interrupts indicate that GPU seems not working... sudo apt install -y libglx-mesa0 libgl1-mesa-dri mesa-utils-extra sudo apt install -y xvfb sudo apt install -y glmark2-es2 $ modinfo panfrost filename: /lib/modules/5.15.93-rockchip64/kernel/drivers/gpu/drm/panfrost/panfrost.ko.xz license: GPL v2 description: Panfrost DRM Driver author: Panfrost Project Developers alias: of:N*T*Cmediatek,mt8183-maliC* alias: of:N*T*Cmediatek,mt8183-mali alias: of:N*T*Carm,mali-bifrostC* alias: of:N*T*Carm,mali-bifrost alias: of:N*T*Carm,mali-t880C* alias: of:N*T*Carm,mali-t880 alias: of:N*T*Carm,mali-t860C* alias: of:N*T*Carm,mali-t860 alias: of:N*T*Carm,mali-t830C* alias: of:N*T*Carm,mali-t830 alias: of:N*T*Carm,mali-t820C* alias: of:N*T*Carm,mali-t820 alias: of:N*T*Carm,mali-t760C* alias: of:N*T*Carm,mali-t760 alias: of:N*T*Carm,mali-t720C* alias: of:N*T*Carm,mali-t720 alias: of:N*T*Carm,mali-t628C* alias: of:N*T*Carm,mali-t628 alias: of:N*T*Carm,mali-t624C* alias: of:N*T*Carm,mali-t624 alias: of:N*T*Carm,mali-t604C* alias: of:N*T*Carm,mali-t604 alias: of:N*T*Camlogic,meson-g12a-maliC* alias: of:N*T*Camlogic,meson-g12a-mali alias: of:N*T*Camlogic,meson-gxm-maliC* alias: of:N*T*Camlogic,meson-gxm-mali depends: gpu-sched intree: Y name: panfrost vermagic: 5.15.93-rockchip64 SMP preempt mod_unload aarch64 sig_id: PKCS#7 signer: Build time autogenerated kernel key sig_key: 11:91:39:AD:08:7D:20:86:21:CA:B4:85:5F:90:99:3A:DC:D2:D0:8B sig_hashalgo: sha1 signature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parm: unstable_ioctls:bool $ sudo modprobe -vv panfrost modprobe: INFO: ../libkmod/libkmod.c:365 kmod_set_log_fn() custom logging function 0xaaaad1f0c460 registered insmod /lib/modules/5.15.93-rockchip64/kernel/drivers/gpu/drm/panfrost/panfrost.ko.xz modprobe: INFO: ../libkmod/libkmod.c:332 kmod_unref() context 0xaaaaf17474a0 released $ lsmod | grep -w panfrost panfrost 69632 0 gpu_sched 40960 1 panfrost $ xvfb-run es2_info EGL_VERSION: 1.5 EGL_VENDOR: Mesa Project EGL_EXTENSIONS: EGL_EXT_create_context_robustness, EGL_KHR_cl_event2, EGL_KHR_config_attribs, EGL_KHR_context_flush_control, EGL_KHR_create_context, EGL_KHR_create_context_no_error, EGL_KHR_fence_sync, EGL_KHR_get_all_proc_addresses, EGL_KHR_gl_colorspace, EGL_KHR_gl_renderbuffer_image, EGL_KHR_gl_texture_2D_image, EGL_KHR_gl_texture_3D_image, EGL_KHR_gl_texture_cubemap_image, EGL_KHR_image_base, EGL_KHR_no_config_context, EGL_KHR_reusable_sync, EGL_KHR_surfaceless_context, EGL_EXT_pixel_format_float, EGL_KHR_wait_sync, EGL_MESA_configless_context, EGL_MESA_drm_image, EGL_MESA_query_driver EGL_CLIENT_APIS: OpenGL OpenGL_ES GL_VERSION: OpenGL ES 3.2 Mesa 21.2.6 GL_RENDERER: llvmpipe (LLVM 12.0.0, 128 bits) GL_EXTENSIONS: GL_EXT_blend_minmax, GL_EXT_multi_draw_arrays, GL_EXT_texture_compression_s3tc, GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_rgtc, GL_EXT_texture_format_BGRA8888, GL_OES_compressed_ETC1_RGB8_texture, GL_OES_depth24, GL_OES_element_index_uint, GL_OES_fbo_render_mipmap, GL_OES_mapbuffer, GL_OES_rgb8_rgba8, GL_OES_standard_derivatives, GL_OES_stencil8, GL_OES_texture_3D, GL_OES_texture_float, GL_OES_texture_float_linear, GL_OES_texture_half_float, GL_OES_texture_half_float_linear, GL_OES_texture_npot, GL_OES_vertex_half_float, GL_EXT_draw_instanced, GL_EXT_texture_sRGB_decode, GL_OES_EGL_image, GL_OES_depth_texture, GL_OES_packed_depth_stencil, GL_EXT_texture_type_2_10_10_10_REV, GL_NV_conditional_render, GL_OES_get_program_binary, GL_APPLE_texture_max_level, GL_EXT_discard_framebuffer, GL_EXT_read_format_bgra, GL_EXT_frag_depth, GL_NV_fbo_color_attachments, GL_OES_EGL_image_external, GL_OES_EGL_sync, GL_OES_vertex_array_object, GL_OES_viewport_array, GL_ANGLE_pack_reverse_row_order, GL_ANGLE_texture_compression_dxt3, GL_ANGLE_texture_compression_dxt5, GL_EXT_occlusion_query_boolean, GL_EXT_robustness, GL_EXT_texture_rg, GL_EXT_unpack_subimage, GL_NV_draw_buffers, GL_NV_read_buffer, GL_NV_read_depth, GL_NV_read_depth_stencil, GL_NV_read_stencil, GL_EXT_draw_buffers, GL_EXT_map_buffer_range, GL_KHR_debug, GL_KHR_robustness, GL_KHR_texture_compression_astc_ldr, GL_NV_pixel_buffer_object, GL_OES_depth_texture_cube_map, GL_OES_required_internalformat, GL_OES_surfaceless_context, GL_EXT_color_buffer_float, GL_EXT_sRGB_write_control, GL_EXT_separate_shader_objects, GL_EXT_shader_group_vote, GL_EXT_shader_implicit_conversions, GL_EXT_shader_integer_mix, GL_EXT_tessellation_point_size, GL_EXT_tessellation_shader, GL_ANDROID_extension_pack_es31a, GL_EXT_base_instance, GL_EXT_compressed_ETC1_RGB8_sub_texture, GL_EXT_copy_image, GL_EXT_draw_buffers_indexed, GL_EXT_draw_elements_base_vertex, GL_EXT_gpu_shader5, GL_EXT_polygon_offset_clamp, GL_EXT_primitive_bounding_box, GL_EXT_render_snorm, GL_EXT_shader_io_blocks, GL_EXT_texture_border_clamp, GL_EXT_texture_buffer, GL_EXT_texture_cube_map_array, GL_EXT_texture_norm16, GL_EXT_texture_view, GL_KHR_blend_equation_advanced, GL_KHR_context_flush_control, GL_KHR_robust_buffer_access_behavior, GL_NV_image_formats, GL_OES_copy_image, GL_OES_draw_buffers_indexed, GL_OES_draw_elements_base_vertex, GL_OES_gpu_shader5, GL_OES_primitive_bounding_box, GL_OES_sample_shading, GL_OES_sample_variables, GL_OES_shader_io_blocks, GL_OES_shader_multisample_interpolation, GL_OES_tessellation_point_size, GL_OES_tessellation_shader, GL_OES_texture_border_clamp, GL_OES_texture_buffer, GL_OES_texture_cube_map_array, GL_OES_texture_stencil8, GL_OES_texture_storage_multisample_2d_array, GL_OES_texture_view, GL_EXT_blend_func_extended, GL_EXT_buffer_storage, GL_EXT_float_blend, GL_EXT_geometry_point_size, GL_EXT_geometry_shader, GL_EXT_texture_filter_minmax, GL_EXT_texture_sRGB_R8, GL_EXT_texture_sRGB_RG8, GL_KHR_no_error, GL_KHR_texture_compression_astc_sliced_3d, GL_OES_EGL_image_external_essl3, GL_OES_geometry_point_size, GL_OES_geometry_shader, GL_OES_shader_image_atomic, GL_EXT_clip_cull_distance, GL_EXT_disjoint_timer_query, GL_EXT_texture_compression_s3tc_srgb, GL_MESA_shader_integer_functions, GL_EXT_clip_control, GL_EXT_color_buffer_half_float, GL_EXT_texture_compression_bptc, GL_KHR_parallel_shader_compile, GL_EXT_EGL_image_storage, GL_EXT_shader_framebuffer_fetch_non_coherent, GL_EXT_texture_shadow_lod, GL_MESA_framebuffer_flip_y, GL_EXT_depth_clamp, GL_EXT_texture_query_lod, GL_MESA_bgra $ xvfb-run glmark2-es2 --fullscreen TBD $ cat /proc/interrupts | grep -i panfrost 64: 0 0 0 0 0 0 GICv3 52 Level panfrost-job 65: 0 0 0 0 0 0 GICv3 53 Level panfrost-mmu 66: 6 0 0 0 0 0 GICv3 51 Level panfrost-gpu
> Hardware support > Debian 11 comes with Mesa 20.3 which supports the Mali 400 and 450 GPUs via the Lima driver, and various Mali G-series and T-series GPUs via the Panfrost driver. This will cover most modern ARM SoCs, including those found in the Pinebook and Pinebook Pro devices. Panfrost supports the Mali T720 (only up to OpenGL 2.1 and OpenGL ES 2.0), Mali T760, Mali T820, Mali T860, Mali G72, Mali G31, and Mali G52. PanfrostLima - Debian Wiki https://wiki.debian.org/PanfrostLima Can I just switch to Armbian Debian 11 and install Panfrost driver to enable GPU on nano pi r4s?
Yes, nanopi r4s has no HDMI output. > Maybe because there is no HDMI output this has been stripped from the config Is there any way to confirm this?
Hi, all. According to: https://www.friendlyelec.com/index.php?route=product/product&product_id=284 > GPU Mali-T864 GPU,supports OpenGL® ES1.1/2.0/3.0/3.1, OpenCL™, DX11, and AFBC And: https://www.rock-chips.com/a/en/products/RK33_Series/2016/0419/758.html > Mali-T860 GPU The NanoPi R4S uses an RK3399 chip, but I do not find any GPU support on the kernel. https://paste.armbian.com/adunopatid ```bash $ ls -l /dev/mali* zsh: no matches found: /dev/mali* ``` Am I missing anything?
