hackerman64
  1. Thanks Igor. Will utilize the digital link for help
  2. Thanks once again for going out of way to help. Will use this information
  3. Hi Tido, Thank you for the reply. I understand what you said but the reason I posted this is because I installed armbian on my Rock64 and then ran the dietpi script. I just don't understand what this error code means sicne it contains the armbian local paths. Apart from dietpi forum. Can you help me identify this error at least? Thank you
  4. Hello, when I run dietpi-software and select some software to install, it gives me this error. Can someone help me? I had to install armbian on my Rock64 and then ran the install dietpi script. Thank you DietPi-Software: G_AGUG │ - Exit code: 100 │ - DietPi version: v6.19.6 (Fourdee/master) | HW_MODEL:22 | HW_ARCH:3 | DISTRO:4 │ - Image creator: Dev │ - Pre-image: armbian │ │ Log file contents: │ Reading package lists... │ Building dependency tree... │ Reading state information... │ Calculating upgrade... │ 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. │ 1 not fully installed or removed. │ After this operation, 0 B of additional disk space will be used. │ Setting up initramfs-tools (0.130) ...^M │ update-initramfs: deferring update (trigger activated)^M │ Processing triggers for initramfs-tools (0.130) ...^M │ update-initramfs: Generating /boot/initrd.img-4.4.162-rockchip64^M │ /etc/initramfs/post-update.d//99-uboot: 3: .: Can't open /etc/armbian-release^M │ run-parts: /etc/initramfs/post-update.d//99-uboot exited with return code 2^M │ dpkg: error processing package initramfs-tools (--configure):^M │ subprocess installed post-installation script returned error exit status 1^M │ Errors were encountered while processing:^M │ initramfs-tools^M │ E: Sub-process /usr/bin/dpkg returned an error code (1) │ │ │ │ Unable to continue, DietPi-Software will now terminate.
