mg-to
Posts
2 -
Joined
Last visited
Content Type
Forums
Store
Crowdfunding
Applications
Events
Raffles
Community Map
Posts posted by mg-to
As a newcomer, I have to start by thanking balbes150 for his excellent work.
I'm running my first tests with Armbian With following environment:
- box: A5XMax with 4GB RAM 32GB disk
- image: Armbian_5.68_Rk3328-tv_Ubuntu_bionic_default_4.4.154_desktop_20190110.img
- FDT: /dtb/rockchip/rk3328-evb.dtbArmbian boots without problems from microSD card (Sandisk Ultra 16 GB) and runs fine.
When I try eMMC installation and run /boot/create-mbr-linux.sh, I get following output:
Start script create MBR and filesystem /dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro 0 0 /dev/mmcblk1 Start backup u-boot default dd: failed to open '/dev/mmcblk1': No such file or directory Start create MBR and partittion Error: Could not stat device /dev/mmcblk1 - No such file or directory. Error: Could not stat device /dev/mmcblk1 - No such file or directory. Error: Could not stat device /dev/mmcblk1 - No such file or directory. Start restore u-boot 8192+0 records in 8192+0 records out 4194304 bytes (4.2 MB, 4.0 MiB) copied, 0.195129 s, 21.5 MB/s Done
It seems that the script selects /dev/mmcblk1 as DEV_EMMC, but /dev/mmcblk1 does not exists, while /dev/mmcblk0 is there.
This is the relevant section of /proc/mounts, that is used by the script for evaluating DEV_EMMC value.
/dev/mmcblk0p2 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 /dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro 0 0 /dev/mmcblk0p2 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
This is the output of ls -lh /dev/mmc*
brw-rw---- 1 root disk 179, 0 Jan 10 09:04 /dev/mmcblk0 brw-rw---- 1 root disk 179, 1 Jan 10 09:04 /dev/mmcblk0p1 brw-rw---- 1 root disk 179, 2 Jan 10 09:04 /dev/mmcblk0p2 -rw-r--r-- 1 root root 12M Jan 10 22:19 /dev/mmcblk1 brw-rw---- 1 root disk 179, 32 Jan 10 09:04 /dev/mmcblk2 brw-rw---- 1 root disk 179, 64 Jan 10 09:04 /dev/mmcblk2boot0 brw-rw---- 1 root disk 179, 96 Jan 10 09:04 /dev/mmcblk2boot1 brw-rw---- 1 root disk 179, 128 Jan 10 09:04 /dev/mmcblk2rpmb
I'm tempted to modify create-mbr-linux.sh and to force
DEV_EMMC=/dev/mmcblk0and to do a similar modification in /root/install.sh, where there is the same mismatch, but I prefer to ask for your suggestion before taking and risk.
Mauro
Armbian for TV box rk3328
in Rockchip CPU Boxes
wdtz,
thanks for your reply. I didn't check the dtb, I've simply selected the dtb selected by another user with the same device (A5X MAX) . So it seems that I'm using a wrong dtb and that I have to
- get the right dtm by extracting it from android.
- put a reference to it in /extlinux/extlinux.conf
Am I correct?
