mpons
  1. Hi, I've had similar problems with my C2. USB would not power up any device except the internal hub. The above workaroud seems to work for me. Questions : Considering this : dmesg [...] [ 2.804560] phy phy-c0000020.phy.1: Linked as a consumer to regulator.3 [ 2.804955] dwc2 c9000000.usb: c9000000.usb supply vusb_d not found, using dummy regulator [ 2.805002] dwc2 c9000000.usb: Linked as a consumer to regulator.0 [ 2.805009] dwc2 c9000000.usb: c9000000.usb supply vusb_a not found, using dummy regulator [ 2.806314] phy phy-c0000000.phy.0: USB ID detect failed! [ 2.806322] phy phy-c0000000.phy.0: phy poweron failed --> -22 [ 2.806395] dwc2: probe of c9000000.usb failed with error -22 [ 2.806604] dwc2 c9100000.usb: c9100000.usb supply vusb_d not found, using dummy regulator [ 2.806627] dwc2 c9100000.usb: Linked as a consumer to regulator.0 [ 2.806633] dwc2 c9100000.usb: c9100000.usb supply vusb_a not found, using dummy regulator [ 2.867643] dwc2 c9100000.usb: dwc2_check_params: Invalid parameter lpm=1 [ 2.867648] dwc2 c9100000.usb: dwc2_check_params: Invalid parameter lpm_clock_gating=1 [ 2.867651] dwc2 c9100000.usb: dwc2_check_params: Invalid parameter besl=1 [ 2.867655] dwc2 c9100000.usb: dwc2_check_params: Invalid parameter hird_threshold_en=1 [...] I wonder if this patch is actually applied in the latest armbian version (I expect not seeing the latest github commit, but I can really tell) https://patchwork.kernel.org/patch/10785943/ On a side note I also have another dmesg error but inconsistent (not on every boot sequence) [ 19.535969] meson-i2s-dai meson-i2s-dai.0.auto: Unable set to set i2s description [ 19.535980] meson-i2s-dai meson-i2s-dai.0.auto: ASoC: can't set meson-i2s-dai.0.auto hw params: -22 This is repeated 20 times Best,
