Hello, thank you all so much for your work, very much looking forward to using it!
I tried building the current dev image debian and ubuntu without desktop for my orangepi3 (without eMMC) (instructions worked great!) but when I power it on, it does not show in the network, its connected via LAN.
I also tried Nico and Krachlates image with the same result.
Using the image from OrangePi, it gets an iP and connects.
I sadly cannot check what the output is as I have no HDMI cable around (sad but true), jus wondering if there is something I'd need to do in order to make it connect to the Network? IPs are assigned using DHCP and it works fine for Raspis that I have running. For the raspis I have to put in an `ssh` file to enable ssh, I thought maybe there was something similar regarding network for armbian but I did not find something like this mentioned?
thanks in any case, maybe I just need to wait for an official image from you guys.
