Hello,
I've found a few logrotate bug reports in search, but they are not related to a "HDD" install.
I have two armbian systems on different boards set up and installed on SD cards. Both systems have the email facilities set up, which is why I found out about this.
This is what I get once a day via email from each of the systems:
X-Google-Original-From: root@cubie (Cron Daemon)
Received: by cubie (Postfix, from userid 0) id 5FC6511FA06; Mon, 25 Mar 2019 06:25:13 +0000 (UTC)
To: root@cubie
Subject: Cron <root@cubie> test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )
MIME-Version: 1.0
Content-Type: text/plain; charset=UTF-8
Content-Transfer-Encoding: 8bit
X-Cron-Env: <SHELL=/bin/sh>
X-Cron-Env: <PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin>
X-Cron-Env: <HOME=/root>
X-Cron-Env: <LOGNAME=root>
Message-Id: <20190325062513.5FC6511FA06@cubie>
Date: Mon, 25 Mar 2019 06:25:13 +0000 (UTC)
/etc/cron.daily/logrotate:
logrotate_script: 2: logrotate_script: /usr/lib/rsyslog.hdd/rsyslog-rotate: not found
error: error running non-shared postrotate script for /var/log.hdd/syslog of '/var/log.hdd/syslog
error: error running shared postrotate script for '/var/log.hdd/mail.info
/var/log.hdd/mail.warn
/var/log.hdd/mail.err
/var/log.hdd/mail.log
/var/log.hdd/daemon.log
/var/log.hdd/kern.log
/var/log.hdd/auth.log
/var/log.hdd/user.log
/var/log.hdd/lpr.log
/var/log.hdd/cron.log
/var/log.hdd/debug
/var/log.hdd/messages
run-parts: /etc/cron.daily/logrotate exited with return code 1
The only rsyslog-rotate script is in /usr/lib/rsyslog/rsyslog-rotate which is different from /usr/lib/rsyslog.hdd/rsyslog-rotate
This is the rsyslog config which calls said script: /etc/logrotate.d/rsyslog
apt-file reports that said file belogs to the rsyslog package:
# apt-file search /etc/logrotate.d/rsyslog
rsyslog: /etc/logrotate.d/rsyslog
Now, before going deeper, I assume that the issue is one of the two:
Typo in a armbian-maintaned rsyslog package
Typo in a serach/replace script during the hdd install
I would appreciate pointers to which repos I have to go to to so I can submit a PR.
Cheers,
Kaurin
