maxmen77
6 -
Igor, thank you! # blkid /dev/mmcblk0p1: UUID="ceb0bbd5-418c-4e46-b120-5ebc4d0e5824" TYPE="ext4" PARTUUID="27105329-01" /dev/sda2: UUID="f135e85e-d58b-48e4-a704-8c5f61ff1849" TYPE="ext4" PARTUUID="175eabfb-238c-5042-b941-fae162ae83ec" /dev/zram0: LABEL="log2ram" UUID="32c412e4-80d5-4536-b3d5-ad087a516143" TYPE="ext4" /dev/mmcblk0: PTUUID="27105329" PTTYPE="dos" /dev/sda1: PARTUUID="42037aed-ed0e-a147-9f5e-618079d27807" /dev/zram1: UUID="5e585ab9-0a82-4eb5-8519-59693cc88250" TYPE="swap" /dev/zram2: UUID="0634003a-8ca5-43b3-9471-37231b6cf5a5" TYPE="swap" armbianmonitor -u link Igor, i solved the problem with your help, thank you! The problem was in the some trash in the file /boot/armbianEnv.txt (trash i dont know where it is from /var/log.hdd/dpkg.log { monthly rotate 12 compress delaycompress missingok no). I remove it and replace to cat /boot/armbianEnv.txt you posted and now it was reboot and working now! It was booted from SSD!
Martynayotte, i check /etc/fstab on the sd-card and on the ssd: SSD: cat /mnt/ssd/etc/fstab # <file system> <mount point> <type> <options> <dump> <pass> tmpfs /tmp tmpfs defaults,nosuid 0 0 UUID=ceb0bbd5-418c-4e46-b120-5ebc4d0e5824 /media/mmcboot ext4 defaults,noatime,nodiratime,commit=600,errors=remount-ro,x-gvfs-hide 0 1 /media/mmcboot/boot /boot none bind 0 0 UUID=f135e85e-d58b-48e4-a704-8c5f61ff1849 / ext4 defaults,noatime,nodiratime,commit=600,errors=remount-ro,x-gvfs-hide 0 1 SD-card: # cat /etc/fstab UUID=ceb0bbd5-418c-4e46-b120-5ebc4d0e5824 / ext4 defaults,noatime,nodiratime,commit=600,errors=remount-ro 0 1 tmpfs /tmp tmpfs defaults,nosuid 0 0 Should i replace /etc/fstab on the sd-card to fstab from the ssd?
Igor, thank you. 1. My SSD drive was not mounted when i start the script. After script ask me to reboot system was rebooted and then i have to mount the ssd maually to /mnt/ssd and i check it - there was copyed by script files: # ls -l /mnt/ssd total 80 drwxr-xr-x 2 root root 4096 Apr 6 12:06 bin drwxr-xr-x 2 root root 4096 Apr 9 17:32 boot drwxr-xr-x 2 root root 4096 Apr 9 17:54 dev drwxr-xr-x 126 root root 4096 Apr 9 18:01 etc drwxr-xr-x 3 root root 4096 Apr 6 10:28 home drwxr-xr-x 18 root root 4096 Feb 9 20:16 lib drwx------ 2 root root 4096 Feb 9 20:20 lost+found drwxr-xr-x 5 root root 4096 Apr 9 18:01 media drwxr-xr-x 2 root root 4096 Apr 9 17:56 mnt drwxr-xr-x 2 root root 4096 Feb 7 15:58 opt dr-xr-xr-x 2 root root 4096 Jan 1 1970 proc drwx------ 16 root root 4096 Apr 9 17:42 root drwxr-xr-x 2 root root 4096 Apr 9 17:58 run drwxr-xr-x 2 root root 4096 Apr 6 12:07 sbin drwxrwxr-x 2 root root 4096 Feb 9 20:16 selinux drwxr-xr-x 2 root root 4096 Feb 7 15:58 srv dr-xr-xr-x 2 root root 4096 Jan 1 1970 sys drwxrwxrwt 2 root root 4096 Apr 9 18:00 tmp drwxr-xr-x 10 root root 4096 Feb 7 15:58 usr drwxr-xr-x 13 root root 4096 Apr 6 11:27 var 2. But the /boot folder on the ssd was empty - may be it is the reason of these troubles? # ls -l /mnt/ssd/boot total 0 # cat /boot/armbianEnv.txt from sd-card # cat /boot/armbianEnv.txt /var/log.hdd/dpkg.log { monthly rotate 12 compress delaycompress missingok no rootdev=UUID=b00453d0-4973-4b88-ad30-ebf605958690 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u The last part of logfile nand-sata-install.log seems like there right UUID=b00453d0-4973-4b88-ad30-ebf605958690 in the /boot/armbianEnv.txt of SD-card. Copying 114912 files to /dev/sda2. Finishing transfer to disk, boot from SD/eMMC Put UUID=b00453d0-4973-4b88-ad30-ebf605958690 to /boot/boot.cmd Put UUID=b00453d0-4973-4b88-ad30-ebf605958690 to /boot/boot.ini I run the script right now and there the same result again - no result. I try to copy files manually from /boot sd card to /boot ssd but there no result also. What i do wrong?
I checked mounted sata disk after nand-sata-install script. /media/MyUSERNAME/New Volume/boot folder and it was empty. There no files at all. It seems like nand-sata-install script did not copyed there nessesary files. Or there must be no files? Does somebody explain what i have to do to boot armbian bootloader from sd-card and system boot from sata? It seems like nand-sata-install script in not working.
I just find /var/log/nand-sata-install.log and there was the next: Sat Apr 6 12:25:50 UTC 2019: Start nand-sata-install. Old UUID: /dev/mmcblk0p1 SD UUID: UUID=ceb0bbd5-418c-4e46-b120-5ebc4d0e5824 SATA UUID: UUID=ff343df0-6da4-4f2c-a0ab-882bffbbedb6 eMMC UUID: Boot: $1 Root: $2 /dev/sda1 ext4 Usage: 1824 Dest: 35338 /etc/fstab: UUID=ceb0bbd5-418c-4e46-b120-5ebc4d0e5824 / ext4 defaults,noatime,nodiratime,commit=600,errors=remount-ro 0 1 tmpfs /tmp tmpfs defaults,nosuid 0 0 /etc/mtab: /dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0 /dev/sda1 /mnt/nand-sata-install.q6FEmR/rootfs ext4 rw,relatime 0 0 /dev/zram0 /var/log ext4 rw,relatime,block_validity,discard,delalloc,nojournal_checksum,barrier,user_xattr,acl 0 0 Files currently open for writing: dhclient 926 root 4w REG 179,1 1113 35899 /var/lib/NetworkManager/dhclient-01c1d280-be03-3996-8781-751811239376-eth0.lease sh 1333 grimakon 2w REG 179,1 8117 186649 /home/grimakon/.xsession-errors xfce4-ses 1556 grimakon 2w REG 179,1 8117 186649 /home/grimakon/.xsession-errors xfwm4 1689 grimakon 2w REG 179,1 8117 186649 /home/grimakon/.xsession-errors xfce4-pan 1698 grimakon 2w REG 179,1 8117 186649 /home/grimakon/.xsession-errors Thunar 1701 grimakon 2w REG 179,1 8117 186649 /home/grimakon/.xsession-errors xfdesktop 1705 grimakon 2w REG 179,1 8117 186649 /home/grimakon/.xsession-errors pasystray 1709 grimakon 2w REG 179,1 8117 186649 /home/grimakon/.xsession-errors blueman-a 1712 grimakon 2w REG 179,1 8117 186649 /home/grimakon/.xsession-errors polkit-gn 1716 grimakon 2w REG 179,1 8117 186649 /home/grimakon/.xsession-errors applet.py 1721 grimakon 2w REG 179,1 8117 186649 /home/grimakon/.xsession-errors xscreensa 1724 grimakon 6w REG 179,1 8117 186649 /home/grimakon/.xsession-errors nm-applet 1727 grimakon 2w REG 179,1 8117 186649 /home/grimakon/.xsession-errors xfsetting 1744 grimakon 2w REG 179,1 8117 186649 /home/grimakon/.xsession-errors pulseaudi 1754 grimakon 11u REG 179,1 12288 186667 /home/grimakon/.config/pulse/f0bef15ed3214c23bc967933014784df-device-volumes.tdb pulseaudi 1754 grimakon 12u REG 179,1 696 186668 /home/grimakon/.config/pulse/f0bef15ed3214c23bc967933014784df-stream-volumes.tdb pulseaudi 1754 grimakon 13u REG 179,1 16384 186669 /home/grimakon/.config/pulse/f0bef15ed3214c23bc967933014784df-card-database.tdb panel-6-s 1855 grimakon 2w REG 179,1 8117 186649 /home/grimakon/.xsession-errors panel-2-a 1856 grimakon 2w REG 179,1 8117 186649 /home/grimakon/.xsession-errors Trying to stop running services to minimize open files: Stopping cron.service Checking again for open files: sh 1333 grimakon 2w REG 179,1 8117 186649 /home/grimakon/.xsession-errors xfce4-ses 1556 grimakon 2w REG 179,1 8117 186649 /home/grimakon/.xsession-errors xfwm4 1689 grimakon 2w REG 179,1 8117 186649 /home/grimakon/.xsession-errors xfce4-pan 1698 grimakon 2w REG 179,1 8117 186649 /home/grimakon/.xsession-errors Thunar 1701 grimakon 2w REG 179,1 8117 186649 /home/grimakon/.xsession-errors xfdesktop 1705 grimakon 2w REG 179,1 8117 186649 /home/grimakon/.xsession-errors pasystray 1709 grimakon 2w REG 179,1 8117 186649 /home/grimakon/.xsession-errors blueman-a 1712 grimakon 2w REG 179,1 8117 186649 /home/grimakon/.xsession-errors polkit-gn 1716 grimakon 2w REG 179,1 8117 186649 /home/grimakon/.xsession-errors applet.py 1721 grimakon 2w REG 179,1 8117 186649 /home/grimakon/.xsession-errors xscreensa 1724 grimakon 6w REG 179,1 8117 186649 /home/grimakon/.xsession-errors nm-applet 1727 grimakon 2w REG 179,1 8117 186649 /home/grimakon/.xsession-errors xfsetting 1744 grimakon 2w REG 179,1 8117 186649 /home/grimakon/.xsession-errors pulseaudi 1754 grimakon 11u REG 179,1 12288 186667 /home/grimakon/.config/pulse/f0bef15ed3214c23bc967933014784df-device-volumes.tdb pulseaudi 1754 grimakon 12u REG 179,1 696 186668 /home/grimakon/.config/pulse/f0bef15ed3214c23bc967933014784df-stream-volumes.tdb pulseaudi 1754 grimakon 13u REG 179,1 16384 186669 /home/grimakon/.config/pulse/f0bef15ed3214c23bc967933014784df-card-database.tdb panel-6-s 1855 grimakon 2w REG 179,1 8117 186649 /home/grimakon/.xsession-errors panel-2-a 1856 grimakon 2w REG 179,1 8117 186649 /home/grimakon/.xsession-errors Copying 114841 files to /dev/sda1. Finishing transfer to disk, boot from SD/eMMC Checking again for open files: sh 1333 grimakon 2w REG 179,1 9722 186649 /home/grimakon/.xsession-errors xfce4-ses 1556 grimakon 2w REG 179,1 9722 186649 /home/grimakon/.xsession-errors xfwm4 1689 grimakon 2w REG 179,1 9722 186649 /home/grimakon/.xsession-errors xfce4-pan 1698 grimakon 2w REG 179,1 9722 186649 /home/grimakon/.xsession-errors Thunar 1701 grimakon 2w REG 179,1 9722 186649 /home/grimakon/.xsession-errors xfdesktop 1705 grimakon 2w REG 179,1 9722 186649 /home/grimakon/.xsession-errors pasystray 1709 grimakon 2w REG 179,1 9722 186649 /home/grimakon/.xsession-errors blueman-a 1712 grimakon 2w REG 179,1 9722 186649 /home/grimakon/.xsession-errors polkit-gn 1716 grimakon 2w REG 179,1 9722 186649 /home/grimakon/.xsession-errors applet.py 1721 grimakon 2w REG 179,1 9722 186649 /home/grimakon/.xsession-errors xscreensa 1724 grimakon 6w REG 179,1 9722 186649 /home/grimakon/.xsession-errors nm-applet 1727 grimakon 2w REG 179,1 9722 186649 /home/grimakon/.xsession-errors xfsetting 1744 grimakon 2w REG 179,1 9722 186649 /home/grimakon/.xsession-errors pulseaudi 1754 grimakon 11u REG 179,1 12288 186667 /home/grimakon/.config/pulse/f0bef15ed3214c23bc967933014784df-device-volumes.tdb pulseaudi 1754 grimakon 12u REG 179,1 696 186668 /home/grimakon/.config/pulse/f0bef15ed3214c23bc967933014784df-stream-volumes.tdb pulseaudi 1754 grimakon 13u REG 179,1 16384 186669 /home/grimakon/.config/pulse/f0bef15ed3214c23bc967933014784df-card-database.tdb panel-6-s 1855 grimakon 2w REG 179,1 9722 186649 /home/grimakon/.xsession-errors panel-2-a 1856 grimakon 2w REG 179,1 9722 186649 /home/grimakon/.xsession-errors dhclient 2796 root 4w REG 179,1 742 35899 /var/lib/NetworkManager/dhclient-01c1d280-be03-3996-8781-751811239376-eth0.lease Sat Apr 6 12:30:52 UTC 2019: Finished Apr 6 13:06:18 UTC 2019: Start nand-sata-install. Sat Apr 6 13:44:39 UTC 2019: Start nand-sata-install. Sat Apr 6 13:46:15 UTC 2019: Start nand-sata-install. And i checked the satauuid in the /boot/armbianEnv.txt and there was correct SATAUUID. Is it normal that "boot: $1" is clear?
Hi! I am trying to install Armbian_5.75_Cubietruck_Ubuntu_bionic_next_4.19.20 to sata ssd (Boot from SD system on SATA from sata-nand-install) to my cubietruck but it still boot from sd-card. It seems like all nessesary files copyed to sata but there no changes in boot config to boot system from sata. After roboot i see the next and there no my 40 GB ssd: df -h Filesystem Size Used Avail Use% Mounted on udev 938M 0 938M 0% /dev tmpfs 202M 11M 191M 6% /run /dev/mmcblk0p1 7.2G 1.8G 5.3G 26% / tmpfs 1006M 0 1006M 0% /dev/shm tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs 1006M 0 1006M 0% /sys/fs/cgroup tmpfs 1006M 108K 1006M 1% /tmp /dev/zram0 49M 3.5M 42M 8% /var/log tmpfs 202M 8.0K 202M 1% /run/user/1000 fdisk -l Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram1: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram2: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram3: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/mmcblk0: 7.4 GiB, 7948206080 bytes, 15523840 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x27105329 Device Boot Start End Sectors Size Id Type /dev/mmcblk0p1 8192 15213343 15205152 7.3G 83 Linux Disk /dev/sda: 37.3 GiB, 40020664320 bytes, 78165360 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x1e31a2b4 Device Boot Start End Sectors Size Id Type /dev/sda1 2048 78165359 78163312 37.3G 83 Linux Disk /dev/zram0: 50 MiB, 52428800 bytes, 12800 sectors Units: sectors of 1 * 4096 = 4096 bytes Sector size (logical/physical): 4096 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/zram1: 502.8 MiB, 527228928 bytes, 128718 sectors Units: sectors of 1 * 4096 = 4096 bytes Sector size (logical/physical): 4096 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/zram2: 502.8 MiB, 527228928 bytes, 128718 sectors Units: sectors of 1 * 4096 = 4096 bytes Sector size (logical/physical): 4096 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes What i have to do to boot from sd-card system from sata?
