@TonyMac32, thanks for the board reference, I am thinking of keeping the extension/HAT adjustant/next to the Tinker board, so the packaging shall be wider, instead of stacking it, doing this would give enough space for cooling system, also give us enough room when we buy other PI pin compatible [but not form factory compatible] Industrial SBC in open market. We need to think of big sized metal based passive cooling, instead of using a Fan, as the industry we target is textiles/spinning mills, the cotton pieces struck inside the fan, [I have visited the factories, they have many drives, I see many times due to cotton dust accumulated inside the fan somehow, the drive halt execution due to increased temperature]
Regarding the power supply, do you have/sell only the power module board,
I am asking something similar to this product , but this seems to output up to 20v, not exact tinker board requirement.
https://www.aliexpress.com/item/1PCS-MP1584-Adjustable-3A-DC-DC-Converter-Step-Down-Voltage-Regulator-Module-Replace-LM2596s/32956356439.html
@martinayotte, I decided to use SC16IS752, as per your advise on Pine64 forum [I had posted similar questions there], thank you so much for this option. Right now, ordered few boards from aliexpress for prototypes, we will have them in 4-5 days in hand. We build some options like 1 SPI to 1 RS-485, 1 RS-232 and 1 SPI to two RS-485 and 1 SPI to two RS-232 extension to get fair options and choices for industry.
https://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20190428180523&SearchText=SC16IS752
7 number of RS-485 is really great, have you done anything with Olimex IND boards, we have plan to take few -40 to 85 Deg C range boards from Olimex when the industry demands it, needs to build similar extension boards.
