davidb
  1. I have the board working with usb bluetooth csr8510 etc, but only with no dvfs enabled. I guess my usb or dvfs settings are incorrect. I've tried various kernel settings and after a week of compiling I have to admit I'm stumped. Please find attached my working kernel config, with usb bluetooth but without dvfs. With dvfs enabled as per Ottuzzi's config the bluetooth adapter gives tx time-out or connection errors that show up in dmesg. I'm using the default bionic bluez v5.48 in both the working and non-working kernels, that leads me to think it's the usb or dvfs settings. I compiled bluez v5.50 from source with no difference. If anyone has any ideas please share? linux-odroidc1-next.config
  2. Thanks for the latest mainline commits for the odroidc1 from Armbian and everyone in the amlogic Kernel Team, I'm delighted to update my odroidc1 to mainline. I've taken the existing default 3.10 odroidc1 kernel config as a base and completed a kernel menuconfig with the same settings, using 5.0.y. I've then removed out anything I don't need. The network settings are carried over from the 3.10 settings, I don't know if this is correct but it works and gives similar sbc-bench results http://ix.io/1Id9 to Ottuzzi (change line 181 in the script). I can post the linux-odroidc1-next.config when I work that out? Usb storage with uas, usb bluetooth csr8510 and docker are working, I've not tested usb wifi.
